Frigidare ltf2940fs1 MOLD ON SEAL
2 Suggested Answers
  • 93 Answers
SOURCE: Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Posted on Jul 03, 2009
FRIGIDAIRE LTF2940FS1 Error Code "PAU"
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Frigidaire ATF6000ES Front Load Washer
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
Acces water and mold
Here is a tip that I wrote that will help you out there...
http://www.fixya.com/support/r4356970-clean_washer
heatman101
Apr 28, 2010 | Samsung WF203ANW Front Load Washer
Mold in washer door seal
Wash it with bleach, that will kill the mold dead. do it once a week when you wipe your washer down you will be in charge of the mold
Jan 11, 2010 | Maytag Neptune MAH6500A Front Load Washer
Mold found in washer
where ever there was moisture run washer for white wash hot/hot with bleach full load or if u have sanitary cycle this should get any mold or algae under drum and entry to pump with front loads its recommended to either wipe excess moisture off seal and or-- leave door open for a few hrs to let seal dry (not advisably with little ones around)--
9
Oct 23, 2009 | Kenmore Washing Machines
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
Mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Aug 24, 2009 | LG WM-2277HW Front Load Washer
The door seal has mold and mildew. It really
first try to clean it with clorox bleach. or some bathroom mold cleaner scrubing bubbles, ect
and if it still needs to be changed look on the computer and find the part shipped to you.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
