Question about D-Link DES 1005 Ethernet Switch
WHEN I CONNECT MY LAPTOP THEN 1 CONNECTED AND 2ND NOT CONNECT
Connected laptop to hdtv via rgb lead but no sound from 2nd monitor(tv)
Sadly, RGB cannot carry sound. In order to hear the laptop sound on the television, You'll need to get an 1/8" headphone connector to RCA (White and Red plug) cable and connect it to the same input as the video is plugged in.
Aug 23, 2011 | Sony VAIO VGN-N130G/W Notebook
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How do i connect my laptop to my printer so i can print things of my laptop
I will try to guess that you want your printer connected to your laptop as wireless.
-first you need to prepare all the things needed and make sure that you connected/installed the cartridges and you have located the port where your power cable needs to plug-in.
-2nd I hope your laptop does have an optical drive (CD/DVD drive).
-on the package of your printer there should be a drivers disk.
-you need to enter the drivers disk on the optical drive then just let it run.
-when you have the GUI of the driver there is an option to install everything.
-make sure that you did not connect your USB cable to the laptop if theres any.
-when running the driver it will come to a point where it will ask you to connect the printer (USB, Network, Wireless)
-if you have the USB cable, use that cable first to connect after you turn on the printer.
-later after the installation was completed, run the disk again then there should be an option to convert the connection from wired to wireless.
-if you dont have the USB cable comeback to me then I will give the the steps to connect it using wireless connection.
Apr 10, 2011 | HP DeskJet F380 All-In-One Printer
Laptop connected to projector get initial message "no signal" then projector continually searches through video, computer 1 and computer 2 - what do I do?
Make sure that you have enabled the 2nd screen output from the laptop. It sounds like there is no signal at the input of the projector. You can check this by connecting a monitor to the 2nd output of the laptop. Often you have to press one of the function keys (F5 possibly) to enable the 2nd screen from a laptop.
Feb 01, 2011 | Hitachi Performa CP-RS55 Multimedia...
Can connect to wireless network with my laptop, but 2nd home PC will not connect, stating that the wireless connection is not connected - yet it also states the hardware is functioning correctly. What do I...
If you know what the spec for your laptop is check the encryption its capable of on a wireless network. If it an older laptop then its probably only 64bit encryption whereas your router is probably 128bit. If this is the case you need to set your router to 64bit encryption for it to work, and then the access key for your 2nd home pc to work
Apr 17, 2010 | Linksys : Wireless-G PCI Adapter with...
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
Trying to connect 2nd remote of wii for mario play
You will have to resync the remote.
1. Press red button in the battery area
2. hit red button on the front of wii
Aug 04, 2009 | Nintendo Wii Console
Laptop can connect to wireless router but not the internet
It could be a conflict with IP adresses. Go to your network connections and right click on wirless connection and go to properties. Scroll down the list to internet tcpip and highlite it. Once highlited go to properties. Then check the set manual ip adress and set it to whatever number you like. leave the bars as is. Do the same to the other laptop but different number.
Aug 03, 2009 | Computers & Internet
2nd laptop will not connect to internet
I'm assuming that your 2nd laptop is wireless? Does your router have encryption? If it has, then you need to get the encryption key from one of the working computers. Access the linksys interface from one of the working computers. Usually this is done by going to http://192.168.1.1 (leave username blank, password is "admin"). Go to Wireless> Wireless Security. Is encryption selected? If yes, get encryption key #1 and use it on the non-working laptop to connect to the router. If encryption is not enabled, go to the steps below.
On the 2nd laptop, click on the wireless icon at the bottom right part of your screen. Look for the linksys router from one of the available wireless networks, click connect and enter in the encryption key when it asks for it (not case-sensitive. Usually it's 10 or 24 digits). If encryption is not enabled, it will not ask for the encryption keys when you hit connect. See what happens.
Jul 05, 2009 | Linksys Wireless-G WRT54GS Router...
D-Link DES 1005 Ethernet Switch Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
