Question about Electrical Supplies
Troy bilt generator
Troy-Bilt 7500 watt , 13,500 watt surge generator, model# 1925. Will not start. Has not been started in past year. Stays inside a garage out of weather. Replaced plug, drained fuel tank and replaced with fresh gas, and installed NEw battery. Unit has spark, and fuel is pumping out of fuel tank line to the carb. If I add small amount of gas down intake side of carb and set choke the generator unit will start, but as soon as small amount of gas runs out the unit stops.
    Top Expert:
  • Electrical S... Master
  • 40,775 Answers
Pull the carby down and clean out the corrosion blocking the main jet
Posted on Jun 07, 2017
5 Suggested Answers
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 4088 Answers
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Posted on Sep 26, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
How do I fix a surging Tecumseh engine on my 1988 Troy-bilt rotor tiller?
Clogged fuel inlet line or fuel filter. It's not getting enough fuel to run
May 09, 2015 | Troy-Bilt Garden
Troubleshoot troy bilt generator
Check that the GFI receptical is not tripped Check that there are no blown fuses or tripped breakers Verify that the engine is running at full RPM If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Aug 30, 2014 | Briggs Stratton Portable Generator 305cc...
I have an old troy built junior tiller, the only numbers found as on the engine. 130202 0135-12 81100107 what year is this model? and were can i get a repair manual?
hello ,you can contact troy bilt at 1-800-269-6215 and check for your manual or go on line troy bilt.com tillers parts manual..add model number,
Feb 06, 2012 | Troy-Bilt Garden
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
How do we get a troy-bilt operators manual for a snowthrower model #31AH63N2711
need a replacement manual for a troy bilt generator 5500 watts
Dec 26, 2009 | Garden
Have Troy Bilt 47279. Need Vacuum Snout.
i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
Nov 06, 2009 | Troy Bilt Walk Behind...
Jun 20, 2009 | Electrical Supplies
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
