Question about Zeiss Humphrey 740 Visual Field Analyzer
Humphrey visual field keyboard not responding
Zeiss humphrey keyboard is not responding.
Why no blind spot dectected
The two most common problems when trying to find a blind spot are: A.) Forgetting to patch the eye, and B.) Choosing the correct eye in the machine itself.
Dec 03, 2015 | Zeiss Humphrey 740 Visual Field Analyzer
How do I hook my external laser printer to my humphrey 740?
In the user manual they list some compatible printers that have a 25 pin parallel connector. We use Lexmark Optra E312L with good results. Once you hook it up, you have to go into one of the setup menus to port it over. The user guide tells the procedure.
Oct 08, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How do I fix the pointer on the touchscreen to be where you touch
You sjould press the patient button and the same time turn it the instrument on keep in button press until you see in tje display the calibration message of the touchscreen
Oct 03, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
Sep 18, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How can I fix my screen ,will not show anything on the field analyzer 740i? Help please
Did you move the brighness control. It is on the right side of the equipment. If not, it could be the video board inside of the equipment
Aug 05, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
May 24, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss Humphrey 740 Visual Field Analyzer Logo
52 people viewed this question
Top Zeiss Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
