Question about Bosch TASSIMO Coffee Makers & Espresso Machines
Tassimo foil stuck
Foil falls inside
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
My ribs came out done but not fall off the bone tender. What cAn I do to achieve fall off the bone tender?
For pork ribs, start by cooking them for 2 hours, at 225, internal temp 160 degrees, then remove from the cooker and foil them.
Be sure to put some of your mop juice, or apple juice inside the foil packets to help them steam and get tender.
Smoke them in in the foil for about 1:45 to 2 more hours. Remove the ribs carefully and vent them. They will be fall apart tender now, and fragile. Let them sit.
After about 10 minutes they will have firmed up again enough to move them back onto the grill for glazing. Use some sauce or a finishing rub to taste.
Feb 16, 2015 | Grilling
Tassimo low water light will not reset
The problem is because Tassimo water tanks have a floating magnet in them which operates the water level switch inside the body. The magnet gets weak over time. Replacement tanks cost too much to be worth the cost. The simple answer is to stick a fridge magnet on the back of the unit (just above the power switch) using blue tack or similar (you can experiment to find the right position). Our unit has been working fine like this for a few years now. :-)
May 24, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo - red water warning light stays on even with full water container
The floating indicator disc may be stuck down. Use a fork to work it back up.
Jun 26, 2012 | Braun Tassimo Espresso Machine/Coffee...
Our tassimo will not stop blinking, all the lights. We have tried cleaning it but that does not work. Where do we send it for repair?
Hey I was having this same problem with blinking and I was shaking the tank trying to get it to engage when my husband, who can fix literally anything, discovered that the magnet in the tank has to engage with the read sensor inside the machine. This magnet is what tells the machine that the water is getting too low. Our magnet gets stuck out of place sometimes. He said it is getting weak and we need to replace it. He used another magnet and held it at the back of the machine beside the tank near the magnet to trick it to engage. It really works! Now, I wonder if Tassimo can send me the perfect size little magnet to replace it. HMMM!
Aug 31, 2010 | Braun Tassimo TA1400
All 4 lights flash when unit (3107) is turned on, machines heats up but won't brew.
Try wiping off the barcode reader window. It's under where the t-disc barcode sits.
Dec 17, 2009 | Braun Tassimo Espresso Machine/Coffee...
Every light blinks and it won't heat water a braun tassimo coffee maker
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Nov 04, 2009 | Braun Tassimo Coffee Maker
Braun Tassimo 3107 lost instructions
where do i get instructions on how to use the braun tassimo 3107
Dec 29, 2008 | Braun Tassimo Espresso Machine/Coffee...
The motor just keeps running after the coffee has completed it's cycle. The only way to shut if down is to turn off the unit. I've tried descaling the unit but that has not helped.
I've had the same problem and found no documented solution or cause. Calling Tassimo was no help. However I've noticed that it usually happens after trying to close the unit when the T disc was not lined up correctly. This pierces the foil in the wrong place. If you run it like that, OR if you open it back up, line the T disc up and reclose; it will spray water and coffee grounds all over. It seems some of the coffee grounds or a piece of foil from the T disc can get stuck in the little switch on the left side bottom of the closing mechanism. This switch indicates to the machine that it is closed. So if the switch gets stuck closed, the machine can think it is closed when it is really open. This prevents a failsafe interrupt from operating which would normally stop the pump and reset the stuck faulty logic in the machine. So the solution is to clean the machine very well in the area around the T discs. This includes removing, cleaning(inside and under), and replacing the part that pierces the T discs. It may look like it is all one piece, but you can pry it up with a butter knife.
Aug 29, 2008 | Braun Tassimo Hot Beverage System - T-DISC...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
