Question about Simmons Video Cameras
White pictures on all settings - Simmons Video Cameras
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
How do i set my G11 to take black and white pictures
Set your camera to B/W as described in the "Changing the Tone of an Image" section beginning on page 82 of the manual.
Aug 15, 2012 | Canon PowerShot G11 Digital Camera
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
In daylight every photo whites out can you help
Take a look at the settings on your camera. There should be a way to change the white balance. White balance is used when you shoot a photo in the direct sunlight. Have you ever noticed the whites in a picture suddenly look blue? This is because your white balance is turned off or not in the correct mode. The same goes for your pictures that look too white. Take out your camera guide if you have one and look up White balance. You should be able to find the correct settings for the pictures you are trying to take.
Hope this helps.
May 10, 2009 | Olympus FE-330 Digital Camera
Picture is white
Don't know your specific camera, but it sounds like you have it set on manual (does it have P, A, S, M settings?) with a long shutter speed. This would let in a lot of light outside, and make all of your pictures blurry.
Change your setting to P (program) or Auto (automatic) and see if that helps.
Mar 18, 2009 | BenQ DC E53 Digital Camera
Burning
i do not understand -/+ button and reading tell me in the simple language.My question is in white colour bird feathers are always very bight i can not see the detail in it how i cam solve this problem if i increase the shutter and apperture the picture became dark.
Oct 22, 2008 | Nikon D80 Digital Camera with 18-135mm...
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Nov 03, 2006 | Fuji FinePix S5100 Digital Camera
Video Cameras Logo
49 people viewed this question
Top Simmons Video Cameras Experts
Are you a Simmons Video Camera Expert? Answer questions, earn points and help others
