Door lock broke after replacement of tube seal
We recently had to replace the door seal to our ASKO washing machine. We had an appliance repair man do the work because I didn't want the hassle of doing myself. Since the seal was replaced, we have had issues with the door locking mechanism. The washing machine gives the error code "LE" (locking error). We had the same repair man back and he said that it is a bad door lock and control board which requires replacement. He is claiming that the bad door lock and control board have nothing to do with the replacement of the door seal but it was locking just fine prior to fixing the door seal. Does anyone have any experience with these issues? Is it likely that the replacement of the door seal caused the locking issues or is it just bad luck? Thank you
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 1462 Answers
SOURCE: Washing machine door lock
undo clamp holding door gasket on cabinet and peel gasket back in the area of the door catch.
door lock is just held in by 2 screws from the outside and will come away when these are undone. on some models, there is also a small diameter pipe going to the door lock and take this off. note where wires go before removing them
Posted on Jun 25, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
SOURCE: Door seal replacement
1 Open filter cover and remove screw,slide plastic to right and remove.
2 Remove 2 screws from door hinge,lift and remove door.
3 Remove spring tensioned wire from groove in rubber door seal and ease rubber off front cover
4 Remove soap dispenser and remove the screw this reveals.
5 Remove 2 screws from bottom of front cover.Push cover upwards and remove.
6 Place to one side being careful not to damage wires to door switch.
7 Remove spring holding rubber to drum and ease off rubber door seal
8 Replacement is a reverse of the above
Posted on Jul 27, 2008
Model W0611. How do I replace the door seal?
Hi John, the following YouTube video link may help, if this is not your model there is a further link in the video showing more ASKO machines, both links are shown below.
Trust this helps, regards Alan.
Washer Door Seal Replacement Asko Washing Machine Repair Part 8081128
Washing Machine Repair Help
Jun 08, 2015 | Asko Washing Machines
Asko 10505
cylicon can easily fill the gap. it works. you can get this from a hardware store in tube .
hope this helps
Apr 15, 2014 | Washing Machines
My 10 yr old 1895b leaks during the drying cycle
The most common issue on these units is the door seal. The seal around the door will break down over time not sealing real well. You would need to order and replace the door seal to fix this issue on this unit.
Appliance & Refrigerator Repair
Mar 23, 2011 | Asko Dishwashers
I have the parts but need the instructions to install a new lock on my Asko frontload Washer/Dryer WD22M19.
Disconnect power then remove the clamp that holds the door gasket to the outer lip of the door opening. Once the clamp is off, peel the door gasket off near the door lock. Remove the screws securing the door lock to the front panel and take the lock out of the machine cabinet. Transfer the wires to the new lock then install it into place. Put the door gasket over the outer lip of the door opening and secure it with the clamp to complete the repair.
Oct 25, 2010 | Asko WCAM1812 Front Load Washer / Dryer
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Jun 11, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
