Question about Electrolux Frigidaire Refrigerator Control Board 241836002
Beep signal and a CE show in the panel - Electrolux Frigidaire Refrigerator Control Board 241836002
Replace the 9V battery in a Frigidaire Upright Freezer Model GLFU1767FW4?
Hello Kerry;
My name is Peter. I am a retired field service refrigeration technician.
You do not have a 9V battery in your unit. It is usually located on the right hand side of the bottom toe plate. There is a small door. This is just a batter backup if you loose cooling or power.
CE means Communication Error. It is like the check engine light on your car. It just tells you that there is something wrong. The 'd' means door seal. There are no sensors or electronics connected to your door seal.
1.) Is your freezer fan running?
2.) Is your lower back condenser fan running?
If they are running the problem is with your main control board. This is located behind your freezer, on the left hand side and mounted on the side wall with several screws. This is a easy part to replace.
PART NUMBER: 216979700 Cost: $134.00
There are only several connectors on the back and a main cable connector.
If you elect to do the work your self, make sure you ground yourself by touching bare metal. Static electricity will knock out a board. Needless to say before the start of work unplug your unit.
If you were to call me when I was a service tech, I would double the part cost plus at least $140.00 labor.
Jan 03, 2015 | Frigidaire Freezers
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
I have an upright Sears kenmore Elite Freezer that beeps CE ever 12 hours and I have to hit the reset button to make it stop. Repair tech said I need to replace the door. Has to be simpliar solution
does it have a back up battery? spending 450 to fix it is not kool. the speaker needs to be cut ! buy a temp gauge, it's how we did it in the old days.. you could even get one that has a alarm at target for 20.00.. like the one used to cook a turky..
Oct 31, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
It keeps beeping saying to CE but everything works. It's not defrosting and compressor still runs.
if it is old, you may want to contact the manufacturer for details on a recharge for the freon
Jul 07, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Beeping coming from freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My GE upright freezer constantly beeps!
It sounds like this is a a non DIY issue. there is really not much you personally can do.
Contact an authorized servicer fir best results
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 13, 2017 | GE Freezers
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
Freezer alarm beep can't reset showing CE then -10/CE 0 food ok
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire FRF170FF Freezer beeping
This is probably the defrost cycle. The beeps are the high temp alarm. It is probably overly sensitive.
Jul 04, 2008 | Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Electrolux Frigidaire Refrigerator Control Board 241836002 Logo
35 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
