Question about HP Photosmart C7280 Printer
My scanner is not working
It wont scan anything and says to refer to manual
tborn6
  • 700 Answers
SOURCE: My scanner won't work.
look dor the hp imaging solution on the bottom of your computer screen. Click on it and when the screen come up clip on the button that is closest to what you are trying to do.
Posted on Dec 21, 2008
  • 8 Answers
SOURCE: no scan option
uninstall printer software and then reinstall from cd that came with it if you have it if not you can download from hp solution center.
Posted on Dec 29, 2008
ziraffa
  • 827 Answers
SOURCE: Scanner won't work
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP J5780) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 09, 2009
SOURCE: scanner not connected
hi,
Click on following link and follow the document,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01388134&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
regrads,  raj_p5983
Posted on Jan 29, 2009
Riztech
  • 731 Answers
SOURCE: scanner does not work
Please click here for the solution
Regards,
Riztech
Posted on Apr 08, 2010
When i scan a barcode why do i have to push enter?
Scan these three barcodes from the LS2208 Product Reference Guide:
Scan Options
Data Suffix
Enter
The scanner will then be programmed to send an enter after every barcode you scan.
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/5880809a.pdf
Aug 11, 2014 | Symbol LS 4278 Barcode Scanner
Why won't my BC145XL scan
push manual on the scanner push manual again to see if the channel changes if so then push the scan button , if still no scan see if the volume is turned up. if not turn it up and see if you have any white noise , if you have what is called white noise turn the squelch till the noise is gone then press scan if it still does not scan you may have all the channels locked out and if so they need to be unlocked refer to the manual to know how to unlock channels then try again if that does not work scanner may need to be repaired
Jul 02, 2014 | Uniden BC350C Base Scanner
Can't scan- Refer to device documentation to
Try using widows paint. Look in windows accessories off the start program menu. If you open windows paint, look for open file from "Scanner or Camera". Most likely you can get the scanner to work again in Vista. Otherwise...try Vuescan scanner software. I think you can get a free trial period online and it should also work. You'll have to pay for that if you like it.
May 19, 2010 | HP OfficeJet 6310 All-in-One Printer...
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
No scan option
Dec 29, 2008 | HP Photosmart 2575 All-In-One Printer,...
Scanner wont scan
if it won't allow you to use the buttons then go to page 17 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) about half-way down the page. good luck!
Dec 05, 2008 | Radio Shack Pro-95 Handheld Scanner
My scanner won't work. When I push the Scan/Reprint button and tell it to scan to the computer, it says it is scanning for a little while and then says "Scan error. Try scan from computer or see...
Dec 05, 2008 | HP PhotoSmart C4480 All-in-One Printer ...
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
HP Photosmart C7280 Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
