Question about Whirlpool Cabrio WTW6800W Washer
My Whirlpool Cabriol WTW5500XWO works find until it gets to the spin cycle than stops. The door light is off. When I hit pause and restart it completes the cycle. My wife also mentioned that the clothes are coming out hot. The rinse cycle should be cool. Any thoughts?
jsrock516
  • 5911 Answers
SOURCE: door locked/ cycle won't complete
If you need to get the washer door open, there is a manual release lever that you can use. The following links explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now, with your clothes rescued, the next link explains the "F11" error:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
I know it seems like a lot with the second link. In most cases I have found, the CCU is the cause of the F11 error code, but read through the information carefully and doublecheck everything. It can be replaced if you wish to perform the repair yourself. I hope this helps you.
Posted on Aug 18, 2008
ngafm
  • 166 Answers
SOURCE: Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 08, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 256 Answers
SOURCE: The washer will not continue the washing cycle. It
Your problem could be one of the following:
* electronic control board
* door lock/switch assembly
Contact an appliance service company.
Posted on Feb 24, 2010
Daniel S
  • 4323 Answers
SOURCE: my whirlpool duet will go
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Aug 28, 2011
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During every wash cycle the machine stops and the indicator light says dL we then hit pause cancel and have to start the machine on drain spin to finish the cycle
This is your door lock mechanism that is either going out ot has gone out already. How old is your washer? We are a Whirlpool factory authorized parts and service company and if you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We will get the correct part out to you asap.
We hope to be able to get you washing again soon. :<)
Nov 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it would flash a leter and a # F 02 I hit cancel and restarted it the time was all messed up I looked up the code for F 02 and found this page, I will post the link below. it was a drainage problem I cleaned out a trap in the pump really easy to do and it just might fix your problem. Regardless ever Duet owner needs to know this and matain this trap I pulled out a bowl full of stuck in it. Good luck!
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool Cabrio WTW6800W Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
