Question about Tekin Rx8 T8 Gen2 BL Motor ESC Combo 1/8 1900kv TEKTT2317
Tekin rx8 won't power on - Tekin Rx8 T8 Gen2 BL Motor ESC Combo 1/8 1900kv TEKTT2317
2006 rx8 Son flooded it. I changed plugs and wires runs but no power until 4000 rpm is it a pluged cat or something else about 93000 miles just bought car two months ago ran fine when he bought it. no...
If this is a Mazdfa rx8 with a rotary motor then it will probably be as it is supposed to be unless it is turbo powered in which check out the turbo operation. Rotary engines do not have power under 3000rpms as they need to be spinning before the torque range cuts in. The rx8 had a 13b engine and the latest version of the engine had as much power as a standard v8 above 4000rpms and reved to close on 11000 rpms
Dec 14, 2014 | Cars & Trucks
Mazda rx8 lose of power steering
rack and pinion or power steering pump are about the only two things that could be your problem. unless you have a leaking hose
Aug 08, 2010 | Fire Extinguisher Gauge Rx7 Rx8 Miata...
Power steering electronic over hydraulic is not working properly on my 2004 Mazda rx8 no power steering
my 2004 RX8 has the same problem - can you let me know if you get a fix. deantom22@sky.com
Thanks very much
Dean
Feb 15, 2010 | 2004 Mazda RX-8
How do I fix the power steering n my mazda rx8 04?
My RX8 had the same problem. First, change your battery cable ends. On the Positive cable there is a white wire that powers the power steering. It probably has a bad connection at the battery post. I cut the end off my rx8 and just put a regular battery cable end on it and my problem was solved.
Jan 06, 2010 | 2004 Mazda RX-8
05 rx8 intermitten power steering becomes hard to
>> Back to: All Products > Logitech > DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2) > Troubleshooting
Do you have a Logitech steering wheel, or a 2005 Mazda RX8 ?
Get the Mazda towed to a qualified repair-shop;
it is _NOT_ safe to drive it "as is",
given that your "power" steering is becoming "manual" steering, unpredictably.
Sep 14, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
I have a 2005 mazda rx8. After running for a few
sounds like it needs to be taken to a madza approved repairer for then to be plugged in for a dianostic annalisis, too many warning lights for one fuse.
Apr 22, 2009 | 2005 Mazda RX-8
2004 mazda rx8 power steering
The Mazda RX8 has electric power steering there is no fluid. You may have a problem with you electronic power steering control moduel, or the power steering pump
Jan 17, 2009 | 2004 Mazda RX-8
Tekin Rx8 T8 Gen2 BL Motor ESC Combo 1/8 1900kv TEKTT2317 Logo
82 people viewed this question
Top Tekin Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Tekin Toy Expert? Answer questions, earn points and help others
