Question about Motorola CRD3X01-401EES Kit:4 Slot Ethernet Cradle Kit
Pb dhcp CRD3X01 - Motorola CRD3X01-401EES Kit:4 Slot Ethernet Cradle Kit
  • Official Brand Answer
  • 3,100 Answers
Hi
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads
Mark
Motorola Mobility Support
Posted on Jan 17, 2015
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Is the Pb-1709 and the Pb1709a the same
It appears that there is one transistor difference in the two models.
Mar 21, 2014 | Yaesu Ft-902dm Ft-901dm Pb-1709a Pll Unit
Map loading impurient client files kikked out
Oh god, poor you dude. That's an arbitrary PB kick. That means PB believes your client file is hacked or some other nonsense. This is a PB problem, there is no fix, just try to reinstall your game and delete all your player profiles. This is one more reason to hate PB...
Mar 10, 2010 | Video Game Consoles & Games
Just bought PB Ixtreme x5620. i am trying to connect my virgin broadband to the pc. i have netgear router which has the yellow cable in the moden and router and the blue cable in the PC and router. i can...
Can you supply more detail of your network setup? You have a broadband modem, a seperate router and the PC.
For this setup cabling should be ....
1. Phone Socket (Pref. Master socket) to ADSL socket on modem
2. Modem LAN socket to Router WAN socket
3. Router LAN socket to PC Ethernet socket
Usually in this configuration you will have to switch off DHCP on either the modem or the router as they may both be trying to supply IP addresses to your PC. I would suggest disabling DHCP on the router and leaving the ADSL modem to supply IP addresses. If you do this you will have to setup the Router with a valid fixed IP.
Have fun!
Cheers,
Ripface.
Oct 25, 2009 | Computers & Internet
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Dhcp in server 2003 in domain not working
Windows 2003 server supports DHCP. If you don't see in Administrative tool DHCP maybe the DHCP role is not enabled. You can add this role in "Manage your server". You don't need to reinstall win 2003 server.
Another way to access DHCP management tool is: in command prompt type mmc and then File> "Add remove snap-in" then "Add" and select DHCP.
Jan 06, 2009 | Microsoft Windows Server Standard 2003 for...
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Motorola CRD3X01-401EES Kit:4 Slot Ethernet Cradle Kit Logo
29 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
