Question about OE Aftermarket 1963 - 1974 MG MGB Carburetor Return Spring W0133-1758
How do I replace the ignition switch on my 74 MGB
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
After removing the column covers, (screws in holes underneath) The 2 unslotted studs holding the ignition and steering lock assembly onto the column are anti-theft screws. They will turn by hitting them on the edges with a hammer and small sharp chisel - counter clockwise.
Posted on Apr 03, 2016
Diagram of distributer to coil for a 1955 nash
Wire from the ignition points goes to the negative side of the coil. It may be marked #1 on the coil. Power goes to the + side of the coil which might be marked # 15. Should be the only wire from the distributor to the coil. Real good modification for your Metro is replace the transmission with a fully syncro unit out of a 68 or newer MGB. You can also replace the engine with a 68 or newer MGB 5 main bearing engine and keep the positive ground electrical. The engine are identical on the outside but much better power and reliability. It will look all original but drive like a dream. I want a Metro convertible at some point in my life. I love those cars.
Oct 21, 2014 | Cars & Trucks
Mgb problems
The only way the engine would keep running smoothly (not engine pre-ignition running) is that the coil is still getting power. If you look at the coil you will see the supply side of the coil comes from the start switch. There is where you should "start" checking. I recommend you also check the start relay for sticking. Something in the starting circuit is not cutting off the voltage to the coil...allowing power to the distributor points.
May 16, 2014 | 1972 MG B
My 74 MGB turn signals and break lights do not work. Fuse is good, bulbs are good. Gauges work, hazards work, parking lights work. Any suggestions?
I don't have repair info on a model that old, but the normal procedure is to follow the circuit from the brake light switch thru the turn signal switch and find out where you are loosing power.
Do the fuses have power ?
Feb 04, 2014 | Cars & Trucks
I have a 74 MGB. All the running lights are working, except the drivers rear. The side running light, tail light, and licence plate light are all on the same circuit. If I unplug them all I get power, but...
You have a high resistance there, it is very common on all BMC products of that era, usualy a dirty contact on the switch, it is the red wire on the light switch, try pulling it off and also pull one of the big blue ones and push the red on to where the blue one was, see if this gives tail lights when the main or dip is selected (tone wont work as you disconnected it!) if so then the switch is faulty.
Dec 20, 2010 | 2003 Kia Sedona
How do i wire in a bosch relay to the radiator cooling fans via an automatic switch in the top of the radiator to my mgb 1980
connect pin 30 to battery w/ fuse at least 30A, then pin 87 to aux fan positive and the other wire of your fan to ground, connect pin 85 to ignition on and pin 86 connect to your automatic switch
Jun 20, 2010 | 2004 Chevrolet TrailBlazer
JVC KS F90 Radio cassette loses all settings when switched off
Your radio probably needs a constant live to retain the radio settings. It may be that your radio has 2 live wires. 1 live that operates the radio coming from the ignition and 1 coming from a constant live that just gives enough power to retain the memory settings.
If you are going long periods of not using the MGB I would disconnect the battery to stop the it draining. If your battery goes completely flat it will damage the battery
May 16, 2009 | JVC KS-F90 Cassette Player
Ignition switch for a 74 vw super beetle
The plastic ignition switch is held in with a philips screw. You will need to remove the ignition lock cylinder to get to it. A easy way to check is to unplug the wires going into the back of the lock housing and plug in the new switch, without removing anything.
Jan 19, 2009 | Volkswagen Beetle Cars & Trucks
Switching the ignition off loses the preset stations
the red wire and yellow wires are crossed simple fix once radio is off
Sep 28, 2008 | Nakamichi CD-35z CD Changer
Year my car was manufactured
look on the label on your driver door or the door jamb and it should tell you
Jun 29, 2008 | 1991 Ford Explorer
OE Aftermarket 1963 - 1974 MG MGB Carburetor Return Spring W0133-1758 Logo
54 people viewed this question
Top OE Aftermarket GPS Experts
John Feinauer
John Feinauer
Level 1 Expert
Timllfixit
Are you an OE Aftermarket GPS Expert? Answer questions, earn points and help others
