Question about Uniden UDR444 Video Survailance System; Two Weatherproof Cameras, 4.3" LCD Display, Digital Zoom, 480 x 272 Resolution, 500 Foot Range, Motion Detection, Two-Way Audio, microSD Card & Rechargable Monitor Battery
Can not set up
Can not get it to install on to pc
Usb connection settings
No setting required. Install Nokia pc suite in your pc/laptop and Just connect your phone using usb cable to pc or laptop and wait 5-10 minutes it will install all required setting automatically. Then u can see your phone connected in PC Suite application.
Jan 28, 2014 | Nokia 5230 Cell Phone
Hang samsung b5310
You need to update your set's OS and install respective pc suite in your pc. After installing your set's pc suite in your pc try to connect your set with pc.
Nov 01, 2013 | Computers & Internet
HOW TO START INTERNET ON PC FROM AIRCEL SIM
FIRSTLY U NEED SETTINGS OF GPRS FROM AIRCEL SERVICE PROVIDER THEN INSTALL PC SUITE SOFTWARE OF NOKIA IN UR PC THEN APPLY THE SAME SETTINGS IN UR PC SUITE UR WORK IS DONE..........
Jul 19, 2010 | Nokia Classic 2700 Cell Phone
Good day I want to use a sata hard disk and
you will need to put in your windows disc and press f8 or whatever you need to press to gain access to your bios settings once in set your pc to boot from cd not h/d it will begin set up for a new install and ask if you want to install a third party sata disk etc click yes at this and follow prompts, restart pc and change bios settings back to h/d detection should then work.
May 09, 2010 | Dell (E210882) Motherboard
CANT CONNECT TO PC
1st Option
FIrst of all if you are trying to install the program from the CD that is provided with the samsung mobile then do not use it.
Uninstall the program from the laptop/PC if you already installed it.
Download the Latest version from here PC SUITE
Click on the Software tab and then "Download" against the PC Studio.
Download and then install and make sure you do not connect the mobile to the PC before installing the full software.
once installed select from the phone
Menu--Settings--Phone Settings--PC Connections--select pc suite --save.
and then connect the mobile with the Data cable.
or
2nd Option
Try this:(if you don't want to install the PC studio)
Menu--Settings--Phone Settings--PC Connections--select Mass Storage and Save.
Now try to connect it.A window will pop up and ask you to use the following for opening up and you select the folder option.
If you don't see a pop up then you see it in my computer as removable disk.
P.S. you will only be able to use your micro SD card content with the 2nd option.
Good Luck.
Apr 17, 2010 | Samsung SGH-S5230 Cell Phone
Samsung C3060R driver fo Windows 7
uninstall again your pc studio, restart you laptop and reinstall your pc suite, but before you do install it, try to do this trick, right click the pc studio, select properties, then select run in compatability mode of xp and vista, then select run as administrator, select apply and ok. it will install, there are times that windows 7 will inform you that the program not installed, you will be having two options, select, '' install the program with recommended settings''.
once installed, connect your phone to your laptop, select settings on you pc suite, select connections, select usb, this will command the pc suite to search for phones attached to usb ports. once searched, it will install your phone automatically and will look for appropriate device drivers for your phone through your pc suite, once connected you are set.
if this doesn't fix your problem, try updating you device through device manager, direct your device installation by browsing the folder to your samsung pc suite and unchecking the automatically install the best driver and checking the box for include the drivers on this folder.
regards.
Mar 06, 2010 | Cell Phones
My samsung phone is not connecting through data cable with my pc. i bought a new samsung set of beat addition 2 days before for using internet through data cable. but my phone is not connecting with my pc...
run again your pc studio cd software installer..
by default, it will play and give the swf home page where there is an option for install usb driver. select install usb driver in order to install your usb driver but before installation disconnect your phone from pc and remove the usb cable. once it's installed, right click your PC studio and select open automatically when device is connected.
>>on your phone, select settings,select settings for your pc connections, check ask for connections and reconnect your phone.
Feb 21, 2010 | Samsung Beat SGH-T539 Cellular Phone
How to use PC suite
Dear ,You have to install the NOKIA PC SUITE software in your pc and then use data cable to connect your pc and your phone.Install settings for PC SUITE SUPPORT in phone(Settings will automatically start to install in ur phone when u cnnect it to ur pc.
Nov 18, 2009 | Nokia N73 Cellular Phone
"failed to set network" entry when trying to connect to internet
make sure that you have installed lancard driver for your new PC go to device manager and check it
Apr 22, 2009 | Computers & Internet
Fax problem
I guess you run win xp.
Did you install the whole mfl-pro suite? If not, do so. Check the installation by clicking installation check within the brother programm (start/progr./brother/installation check).
After a good installation press start/progr./brother. There you will find a pc-fax set-up. With that you can fax out of your pc thru the mfc.
If you want to receive fax on your pc you have to change settings within the machine . see handbook software which is part of the installation software cd how to do the right settings (chapter I 6 pc-fax)
Oct 13, 2007 | Brother MFC-5460CN All-In-One InkJet...
Uniden UDR444 Video Survailance System; Two Weatherproof Cameras, 4.3" LCD Display, Digital Zoom, 480 x 272 Resolution, 500 Foot Range, Motion Detection, Two-Way Audio, microSD Card & Rechargable Monitor Battery Logo
32 people viewed this question
Top Uniden Electronics - Others Experts
cwradio73
richie46
Are you an Uniden Electronics - Other Expert? Answer questions, earn points and help others
