Question about HP PSC 950 All-In-One InkJet Printer
HP Color LaserJet 3800 PCL paper tray won't close
BigdaddyTDW
  • 62 Answers
SOURCE: Ghost prints on HP-1300
The cartridge could be bad. Just saw same issue earlier on another HP doing the same. Inspected the fuser and it had a place it the middle that the teflon coating was worn off. Try cartridge first, then look at the fuser with flashlight. Do not stick anything into the fuser. Make sure machine is powered down,unplugged and allow it to cool down before attempting to touch area. It will burn you, they get hot!
Posted on Feb 14, 2009
  • 9 Answers
SOURCE: hp laserjet 4050n con't print from automatic paper
1.Make sure the guides on the back of the tray is set properly as well and the pages have not slid back further then they should. Say if you are using letter. Make sure the tray guide are exactly on letter.
2.Often the paper pick up roller gets paper dust on it, and it gets slippery.
Only clean it with a relatively lint free, cotton cloth, dampened with plain water. Any other cleaners can dry out the rubber, and shorten the life on the roller.
3. If you notice the blue pickup roller on the bottom of the tray is getting worn it needs to be replaced. Some times you can get a few thousand more pages out of it by swapping it with the other one that is up in the printer. If find it wears more slowly.
You can remove them by pressing on the release tab sticking out the front of the roller. Take out the tray and you will see another one up in the top where the tray came out.
Posted on Dec 09, 2009
SOURCE: There's a piece of paper jammed in my laserjet
isn't there a panel on the back you can remove?
Posted on Dec 10, 2009
shadiabed
  • 72 Answers
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Posted on Jan 08, 2010
vinay229229
  • 1121 Answers
SOURCE: PCL XL error on HP color laserjet 3600n
Verify printer functionalityTo verify printer functionality, use the following steps:
  1. Turn off the printer and then unplug the Parallel, Serial, or Network data cable from the back of the printer. This will ensure that the information is not being received from the computer or network.
  2. Turn on the printer and verify that the word Ready appears on the printer display.
  3. Print a self-test on the printer by performing the following steps:
    1. Go to the on the printer.
    2. Press the MENU key until INFORMATION MENU appears on the printer display.
    3. Press the Item key until PRINT MENU MAP appears on the printer display.
    4. Press the SELECT button. The printer should generate a print job.
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
  1. Connect the printer directly to the computer. Use an IEEE/1284-compliant cable.
  2. Print a Test Page by completing the following steps:
    1. Click Start and then Settings and Printers .
    2. Right-click the appropriate printer driver.
    3. Select Properties .
    4. Click the General tab and click the button in the lower right-hand corner that is labeledPrint Test Page .
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
  1. Press the MENU key.
  2. Select CONFIGURE DEVICE .
  3. Press I/O MENU and disable Parallel High Speed .
  4. Press I/O MENU and disable Advanced Functions .
  5. Connect the printer to a different location, change parallel/USB/network cables. Bypass switch/hub (if there is any).
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
  • Use lower resolution, such as 600 dpi.
  • Enable or disable Send True Type as Bitmaps .
  • Disable the Print Optimization under Printer Properties => Advanced => Document Option .
Some more steps:
  • Try changing the personality type to Auto/PCL/PS in printer Control Panel.
  • If changing personality does not make any difference, remove the current driver completely (from Server Properties ), restart the system, and install PostScript (PS) driver.
  • While installing the printer driver, select the standard TCP/IP port if the default is HP Port , and vice-versa.
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
  1. Remove any additional memory that has been added to the printer after being purchased. Refer to the User's Manual that was supplied with the printer for memory removal instructions.
  2. Try using a different Font within the application or document in question.
  3. Try to print using the PCL5e driver that came with the HP LaserJet Printing System.
Posted on Dec 21, 2011
Printing thin black lines the length of my color pages, HP laserjet 3800
one question......
do the lines go off the edge of the paper?
if so either the black drum unit or the belt has gone bad.
if the lines stop before the edge of the paper it could be on the print job itself.
go through the menu and look for demo pages or the configuration pages to print and examine them.
Jan 11, 2011 | HP LaserJet 3800 Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
Jan 08, 2010 | HP LaserJet 3800n Printer
Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Feb 07, 2009 | HP Color LaserJet 3500 Printer
HP PSC 950 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
