Question about Edirol Computers & Internet
Can't sync Edirol UA-101 with my computer
I'm trying to sync my Edirol UA-101 to a MacBook, but it came without instructions so I can't get it to work. Specifically, when I turn the unit on the 'sync' light flashes, but when I connect the other end of the USB to the computer it continues to flash, or goes off altogether. Do I have to hook it together in a specific order or something? The driver's installed so it's not that.
smilemaker
  • 790 Answers
SOURCE: Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Posted on Nov 28, 2007
SOURCE: Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Posted on Jan 01, 2009
Dr_Joseph
  • 86 Answers
SOURCE: Contents of box.No instructions.
when you connect the device to the pc it will detect new hardware and you will be ready to go.
you can download the driver for your OS here:
http://www.roland.com/products/en/_support/dld.cfm?ln=en&dsp=0&iCncd=1039
Posted on Jan 25, 2009
Techie2core
  • 42 Answers
SOURCE: i have lost the installment cd for the edirol USB
This link should help:
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=UA%2D25
Posted on Dec 04, 2009
jadiazq
  • 2878 Answers
SOURCE: ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Posted on Aug 31, 2012
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
Ua 101 driver won't install on windows 7 64 bit
Aug 31, 2012 | Edirol UA-101 External Sound System
Hi, my Edirol UA-4fx is having a problem. The Advanced Effects don't work at all. I get audio, but without any of the effects. Nothing lights up on the faceplate except for the blue usb light. I've tried...
Unplug, change the hardwae switch on the unit to "advanced driver" = "off" and reconnect. It seems that the onboard effects are not available when in advanced mode. :(
Dec 28, 2010 | Edirol UA-4FX External Sound System
Jan 19, 2009 | Edirol UA-4FX External Sound System
Nov 19, 2008 | Edirol UA-4FX External Sound System
My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Jun 10, 2008 | Edirol UA-25 External Sound System
UA101 and Blue Screen of Death
try this to make sure that the driver was installed correctly.:
Note: Do not use the “Add New Hardware” Wizard in the control panel. Follow the steps below to install your driver correctly.
1. Plug in the USB cable and power on the device – the New Hardware Wizard will start up (wait for it to start).
2. If Windows asks to connect to Windows Update, click on “No, not this time” and click on “Next.”
3. Select “Install from a list or specified location” and click “Next.”
4. Select “Include this location in the search” and Browse to the folder containing your driver (either on your CD or the folder you downloaded). Click “Next.”
5. Click “Continue Anyway” when the Windows Logo testing screen appears.
6. Click “Finish” when the Completing the Found New Hardware Wizard screen appears.
At this point, you may need to reboot your computer. After restarting, you should check to make sure the driver was successfully installed. Go to Control Panel / Sounds and Audio Devices and make sure your device is listed under “Sound Playback” and “Sound Recording” for audio devices and “”MIDI Music Playback” for MIDI devices. You should also check in the Device Manager to make sure your MIDI or Audio device is listed under “Sound, video and game controllers” with no problems (such as the yellow exclamation point).
If everything is successful to this point, Windows has installed the device correctly and is making it available to any software you need to run. If you can not see your device in your software, you should first try re-profiling the device (different software programs do this differently). If this does not work, you may need to uninstall and reinstall the software. If you still do not see your device, you may need to contact your software vendor for more help.
- Mac OS X -
1. Make sure the Roland/Edirol device and any non-essential USB devices are disconnected.
2. Run the *.pkg installer from the CD-ROM or downloaded driver and follow the onscreen installation instructions. When finished, reboot fully.
3. Plug in the Roland/Edirol device. Ports should now be available in software (you can verify driver availability in Applications > Utilities > Audio/MIDI Setup > MIDI Devices).
- Mac OS 9.X -
Users must first decide if they want to run OMS or FreeMIDI, which can be downloaded from the World Wide Web. OMS is recommended. See the OMS or FreeMIDI documentation for installation and activation details.
Double-click the Edirol installer and follow the onscreen installation instructions.
Note: If you continue to have problems, you may wish to consider upgrading to OS X, as its Core Audio and Core MIDI features make this operating system an excellent base for music applications.
ALSO:
Product: UA-25 UA-101 FA-66 FA-101 UA-4FX UA-1EX
Pop/click/dropout is often a buffer size problem. Be sure to check your Buffer Size setting. You'll find it in the Edirol Icon in System Preferences or in the Control Panel of a Windows machine. Increase your buffer size until the problem goes away.
There are also several settings you will want to make in order for audio applications on a Windows XP computer run optimally.
One of the more detailed websites to walk through these settings is MusicXP.net.
http://www.musicxp.net/tuning_tips.php
Dec 23, 2007 | Edirol HI-SPEED USB (USB 2.0) Audio...
Edirol UA-101
Aug 19, 2006 | Edirol UA-101 External Sound System
Computers & Internet Logo
42 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
