Question about Accuform Signs Attention Examiner Les Lingues Avant Utilisation french Sign - 7" X 10" Adhesive Vinyl
Inverter direct drive 5 kg f8068ldp - Accuform Signs Attention Examiner Les Lingues Avant Utilisation french Sign - 7" X 10" Adhesive Vinyl
LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
Jan 31, 2017 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
What sizes do weight training plates come in?
Weighttraining plates come in a variety of s. In the average gym, the platesusually start from 1.25 kg all the way to 25 kg. In between you can find 2.5kg, 5 kg, 10 kg, 15 kg, and 20 kg plates.
Jul 25, 2012 | Exercise & Fitness
Need to change alternator belt 2003 kia spectra
1. Remove AC and P'S drive belt, if equipped.
2. Loosen generator mounting bolt and adjusting bolt.
3. Remove generator belt.
4. Install new generator belt and adjust to specification.
5. Tighten all bolts to specified torque.
Tightening torque mounting bolt: 27-38 Lb-ft (37- 52 N.m. 3.8 -5.3 kg-m)
Adjusting bolt: 14 - 18 Lb-ft (19 -26 N.m. 1.9 -2.6 kg-m)
6. Install AC and P'S drive belt, if equipped. and adjust to specification.
Nov 28, 2011 | 2003 Kia Spectra
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
How do i change alternator belt 2003 kia spectra
Welcome to FIxYa.com
Replacement
1. Remove AC and P'S drive belt, it equipped.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 20, 2010 | 2003 Kia Spectra
I need a diagram on how to replace a 2001 chevy metro alternator.
2001 Chevrolet Metro 1.3L MFI SOHC 4cyl
Alternator - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner assembly Alternator electrical connectors Accessory drive belt Upper and lower mounting bolts Alternator
To install:
  1. Install or connect the following:
    Alternator and the bolts, do not tighten the bolts at this time
  2. Install the alternator belt and adjust the tension until a deflection of 0.24-0.31 inch (6-8mm) deflection with 22 lbs. (10 kg) of pressure exerted when installing a used belt. On a new belt the belt deflection should be 0.20-0.27 inch (5-7mm) with 22 lbs. (10 kg) of pressure exerted.
    Alternator electrical connectors, then torque the alternator bolts to 17 ft. lbs. (23 Nm) Air cleaner assembly Negative battery cable
    Negative battery cable Accessory drive belt Alternator electrical connectors Alternator
To install:
  1. Install the alternator and hand-tighten the bolts.
  3. Install or connect the following: Upper alternator bolt to 18 ft. lbs. (25 Nm) Lower alternator bolt to 40 ft. lbs. (54 Nm) Alternator electrical connectors Accessory drive belt Negative battery cable
    Fig. Exploded view of the alternator-Metro and Prizm models
Hope thats help (remember rated this).
Feb 18, 2010 | 2001 Chevrolet Metro
Accuform Signs Attention Examiner Les Lingues Avant Utilisation french Sign - 7" X 10" Adhesive Vinyl Logo
91 people viewed this question
Top Accuform Signs Home Experts
Donni Steen
Tom Chichester
Are you an Accuform Signs Home Expert? Answer questions, earn points and help others
