Question about Craig Electronics Craig Smart TV HDMI Adapter and Mouse CVD601
How to install a craig smart tv adapter - Craig Electronics Craig Smart TV HDMI Adapter and Mouse CVD601
Is there any way to use a Craig model cvd601 HDMI smart Tv adapter if the administrator password is lost?
The manual says:
""Forgot lock pattern on Android? Here's a way to reset it.
- Enter wrong pattern 5 times and wait 30 seconds.
- Select "Forgot Pattern" and enter your Gmail acccount username and password.
- Make sure you use the same account that was used to activate the device and double check the password by logging in to that Google account in a browser on a PC. If you don't have access to the original Gmail account, you will need to do a hard reset (which is in the Settings so, how, if you can't get it to boot up?) and lose your settings and apps on the unit. The data on the memory card will not be wiped though.""
I am holding a CVD601 in my hand, and unfortunately there is no "mechanical" reset button anywhere on the thing.
Good luck.
Jan 10, 2018 | Smart Computers & Internet
Is there an adapter to switch tv to smart tv
No, but most Blu-ray players are "smart" players and include a Netflix app as well as other services such as HULU, Amazon, etc. Usually, the Blu-ray player will have stickers or or emblems printed on the box or the on the player itself with "Netflix" , etc.
Connect the Blu-ray player to the TV using an HDMI cable. Connect the Blu-ray player to your router/home network with an ethernet cable or wirelessly if your player has built-in Wi-fi. Once that is done you can go to the Main Menu on the player and select Netflix. That should open the Netflix app and connect you for watching Netflix.
Dec 28, 2015 | Sanyo Televison & Video
Mouse not working right
You mouse is obviously defective so BUY A NEW MOUSE. It's still on warranty? Return it
Aug 09, 2015 | Craig Electronics Craig Smart TV HDMI...
My tv adaptor won't boot
nothing, compatibility issues, will never work with other tv/monitors. ask manufacturer for list of compatible products
Mar 14, 2014 | Craig Electronics Craig Smart TV HDMI...
Wrong resolution on smart tv- cvd601
I made the mistake of selecting the largest of the resolution settings of 1920x1080-50Hz. The CVD601 DOES NOT HAVE A RESET BUTTON! You have to do all your business on screen. So to regain my setting of 1280x720-60Hz, I disconnected from my TV and hooked up to my computer monitor. At that point, I got my picture back and went to settings. Upon restoring the settings in TV Screen Resolution to: 1280x720-60Hz just click and exit. In the US everything is based on the 60Hz cycle. Hence the hickup when you pick anything in the 50Hz cycle. I hope this helps!
Jan 08, 2014 | Craig Electronics Craig Smart TV HDMI...
Craig High Definition LCD TV (15.6 in) power cord
The power source is a 12 volt transformer so you can use a standard universal power supply. A 12 volt DC Power Cord with Auto Cigarette Lighter type Adapter will work in an auto.
Nov 03, 2009 | Televison & Video
I need an AC 12v-5v powr adapter for a PROSCAN TV.
USE a simple laptop adapter thats whhat i did just tell the guy at local comp store 12 volts and 5 amps they should have 1 or able to order it also try a used comp store they abound on craigs list and kijiji canada
Oct 22, 2009 | Proscan 19LA20Q LCD TV
Craig Electronics Craig Smart TV HDMI Adapter and Mouse CVD601 Logo
62 people viewed this question
Top Craig Electronics Computers & Internet Experts
Tony
Barry37
Level 1 Expert
sharky633
sharky633
Are you a Craig Electronics Computer and Internet Expert? Answer questions, earn points and help others
