Question about HP ProLiant ML370 G4 Server
Server serial port not working - HP ProLiant ML370 G4 Server
Dear experts; We have a HP R3000xr UPS, inetend to install the power management software on a server runs windows server 2008 R2 OS. Installed the power manager server software, the following messages...
Is the cable USB or SERIAL?
make sure serial port IRQ is enabled in BIOS
ALso make sure you are using x64 and not x32 drivers for UPS
ALso try getting a USB cable to connect to your UPS device
Feb 17, 2011 | HP R3000 UPS System
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Access server manager 3.6
The DECserver 732 is a high-density, high-performance asynchronous device and remote access server that provides 32 MJ8 (RJ45) serial ports. The DECserver 732's serial ports support either of two sets of software-selectable four-signal modem control signals. The DECserver 732 has AUI and 10BaseT Ethernet connectors. The DECserver 700-16 supports up to eight sessions per port and speeds up to 115.2 Kb/s per port. The DECserver 732 has an external FLASH socket for the customer-installable flashcard. When installed, the flashcard allows self-booting operation. The DECserver 732 runs DECserver Network Access Software (DNAS), which delivers multi-protocol support for TCP/IP, IPX, and AppleTalk networks. DECserver 700 units are designed for tabletop or rackmount configuration
the u need to check these site for more info:
http://www.vnetek.com/s-137-digital-networks.aspx
Jan 05, 2010 | Digital Products Digital DECserver 732...
Need a motherboard with DB25 male RS232 serial port
to get ur motherboard just go to the website of that ,,u can find it bt surfing
Dec 06, 2008 | Intel Server Board S5000PSL - Motherboard...
MS9520 serial connected to the terminal - does not send keys to the terminal server
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Nov 07, 2008 | Metrologic Instruments 9520 Voyager
Cyclades TS100
no it wont work
Feb 02, 2008 | Computers & Internet
Device no detected in COM1
some pads like that work fine on old computers but with the new update from microsoft things like that pad cant be run on new things like the SP2 on windows see if windows sees that it is a pad. any software for it should work on WIN XP
Nov 01, 2006 | HHP TT1500 (004769)
HP ProLiant ML370 G4 Server Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
