Question about Electrolux Washing Machines
Cycle locked cycle will not unlock
Locks unlock and lock constantly
With factory controls the door locks get there signal from the body control module and can be set to lock every time the car gets above 15 mph if a door jam switch has a intermittent connection failure this could cause the door locks to cycle at will.
With a aftermarket alarm most lock and unlock with the key cycle and loose grounds can make these modules cycle the locks at will also.
Nov 07, 2013 | 2003 Chrysler PT Cruiser
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
Sep 18, 2013 | 2001 Toyota Land Cruiser
A friend of mine has a Lexus 1997 ES and his remote control needs reprogramming. How do I do it for him. Thank you so much.
1. Driver's doo opend and unlocked, all other doors closed and locked
2. Inser Your key in ignition, don not turn, remove key
3. using the manual lock/unlock button on ther dirvers door, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times)
4. Shut door
5 Open door
6. Using the lock/unlock button on the direvers door, slowly press and unlock 5 times (count the lock 5 times and the unlock 5 times)
7. With the door open insert you key into the ignition, turn to ON position (don't start), wait 5 seconds. Trun off and remove key.
8. Locks should cycle once (Car will lock and unlock once). If they don't cycle or they cycle more that once, do stips 1-7 over.
9. Using the remote, push lock button, hold for 1 second, release. The locks should cycle once. If not start over and go slower.
10 Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors shoud unlock.
I got this from a site called FixYa (don't have URL). It took me a few tries but it worked like a charm.
Sep 24, 2009 | 1997 Lexus ES 300
How do i program my keyless remotes to my 2003 ford expedition
Cycle the ignition key 8 times to the run position. On the 8th time leave it in the run position. The door locks should cycle ,press the lock or unlock button on the remote,locks should cycle. Press the lock or unlock button on the second remote locks should cycle. Turn igition off, locks should cycle. Good luck
Jul 16, 2009 | 2003 Ford Expedition
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Un work of the doors auto control lexus
4. Shut door.
5. Open door.
10. Close the door.
11. Open the door.
13. Close the door
Long beep to follow if successful.
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
2000 Toyota Sienna Minivan car alarm goes off.
1. Start with key out of the ignition, drivers door is open all others closed and
2. Insert key into ignition (Do not turn) and pull it out.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
(1 cycle = 1 lock and 1 unlock.)
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
Apr 25, 2009 | Chevrolet Malibu Cars & Trucks
Washing Machines Logo
12 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
