Question about Technics SL-1210 Turntable
No power One of my decks has no power going to it. When i turn it on there is nothing.I have tried my other deck in the same socket and works fine so i have ruled that out. I have replaced the fuse and tried original fuse in the other deck and that works fine. I wonder if you might know what needs to be done Cheers
  • Han5olo Nov 03, 2007
    I too have no power to the deck. Im very confused as I have had decks for over 10 years and bnever come acrosss this problem. Does any one know where I can take it too as Im not a very techy guy.
  • 382 Answers
With a voltage meter, open the table back up to where the fuse is under the on off switch. With the table plugged check the voltage meter check the incoming ac prongs for 20V. Also, the 1210 has a voltage switch under the platter to the left
 a little hole for which a flat head screwdriver is needed to switch the voltage. If you live in the UK or outside od the USA it should be on 220V, IF YOU LIVE IN THE USA, IT SHOULD BE ON 110V. If your electricity is 110/120 and its on 220, the transformer is most likely fried. If your electricity is 220V and its set to 110V , then its not getting enough current. Its possible the transformer could have gone bad, with no smell of burn or sign of damage. Also, check board with all the capacitors on it around the motor, check fopr any leakage...
If service Technics for 15 years and sometimes i'll se voltage issues I've never seen before.....
Posted on Oct 28, 2007
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Sep 17, 2007 | Nintendo NES Console
Do I need an amp for my 3head sony real to real tape recorder
You do need an amp of some kind. On the back of the deck will be RCA sockets, in the red and white ones you plug a line cable to the audio in sockets of an amp or receiver. The other two sockets are record. They go to the audio out of the amp.
Jan 17, 2014 | Beltronics TEAC W-600R Home Double...
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
JVC KD-AVX1 Sirius Just Quit
Hi guys i need help i bought a use KD-AVX1 and i don't know how to use it i need help how to get a manual for my radios appresiated your help.
Apr 29, 2007 | JVC KD-AVX1 Car DVD Player
Technics SL-1210 Turntable Logo
360 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
