Question about CRITIKON Dinamap MPS Bedside Monitor
Hadware error SY-20 - CRITIKON Dinamap MPS Bedside Monitor
This problem is with the PNI card.
This card is located next to the front board panel.
Posted on Apr 11, 2015
Error code SY CE displayed plus lights in refrigerator and freezer not working
I appreciate your post, Carol!
Based off the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and the lights are not working. A "SY CE" error code stands for a communication error at start up. This might be a miscommunication within your refrigerator and I would recommend performing a reset in order to correct the issue. To reset your refrigerator you need to disconnect power from it for roughly ten minutes. If this does not help correct your issue you may need to change your control panel or a wiring harness. In order to properly diagnosis your refrigerator you may need to disassemble it and I would suggest having a professional technician out to do so. This will help you avoid any unnecessary part purchases or personal injury. -Matt
Jun 08, 2015 | Frigidaire Refrigerators
Fix my problem get sy cf on my display
Hello Eric espy, thanks for your post!
From my understanding you used the icemaker on your Frigidaire refrigerator and now have a code of "SY CF" on the display. That code of "SY CF" stands for communication failure after power up. This could be a possible communication error between the UIB (User Interface Board) and main control board. I would suggest performing a reset, which should clear any false error codes. If you continue to receive the error I would suggest contacting a professional technician for proper diagnosis and repair. This may help you avoid unnecessary part purchases. -Matt
Feb 22, 2015 | Frigidaire Refrigerators
What does EI28BS36IS3 blinking lights mean
Are all of the lights flashing or is it flashing a code like Sy EF or Sy CE? If so the ef would indicate the evaporator fan circuit has a problem, and if it is SY CE it would indicate a communication error.
Feb 19, 2015 | Electrolux Refrigerators
SY CE error on Electrolux Refrigerator Display. I unplug the unit and it works for about several hours then the power outage alarm will go on and off several times and then unit will error out the SY CE...
I have a very similar issue with my GE in wall oven, circa 1999. I learned it was due to one of two issues.
1. The touch panel keypad is shorting out somewhere along the ribbon wire circuit. Replacement likely needed.
2. The microcontroller brain of the oven is faulty. Replacement likely needed.
My issue was the keypad. I personally went to RadioShack and prototyped a new circuit board to reverse engineer the keypad. The flimsy keypad replacement was $244.00 for a new one, however they no longer make the keypad. For less than $20 and a little solder I have a fully functioning replacement.
Oct 29, 2014 | Refrigerators
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
How do i clear Error code E.Puch
E.puch power unit changed
power unit identification was changed, with a avalid power circuit this error can be reset by writting to SY.3. If the value displayed in SY.3 is written, only the power-cricuit dependent parameters are reinitialized. if any other value is written, then the default set is loaded . On some systems after writing SY.3 a power-On -Reset is necessary........
Apr 25, 2013 | Inverter KEB COMBIVERT F5
Sansui sy 20 eye tv- when power on/off only red led works, green led not working
Please give me sansui sy 20 eye service menu code...pls urgent
Jan 24, 2011 | Televison & Video
I have a prblem in the F5 keb combivert it's show Error E.OC & E.puci & E.Puch could you please advice us with the proper solution thanks
E.puci During the initialization the power circuit could not be recognized as invalid.
E.OC Overcurrent
Apr 11, 2010 | Inverter KEB COMBIVERT F5
Printer error message
Hi ,
Usually this error comes up because of problem with software,
Uninstall and reinstall the software with the help of CD from hadware manufacturer..
Please let me know if this solves your problem
Thanks.....Robosoft..
Dec 17, 2007 | HP Officejet 4215v All-in-One Printer
CRITIKON Dinamap MPS Bedside Monitor Logo
127 people viewed this question
Top CRITIKON Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a CRITIKON Health and Beauty Expert? Answer questions, earn points and help others
