Question about Microwave Ovens
Problem with microwave nn-sa630w
When i open the door after the microwave stops it start againeand feep runing until i close the door
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Posted on Nov 07, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
SOURCE: Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Posted on Apr 20, 2008
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
Why does my microwave keep running/heating until I open the door? what can i do about it?
Sounds like a problem with the control panel. Further diagnostic testing would be required, however, as there can be other causes.
May 10, 2014 | Oster OGB61101 Microwave Oven
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
Our Microwave (JEM25GY/WY) finishes its program, shuts off and beeps; when I open the door to take out the food, the fan starts up again and doesn't stop until I close the door. Serious? Can it be...
Yes! this should be checked right away to make sure the magnetron is not running with the fan when the door is open , it may be a problem with one of the door switches going bad, left unchecked it probably blow the fuse in the microwave killing all power, but it is quite repairable. But please do not use until it has been checked out by a professional for safety reasons.
Feb 11, 2011 | General Electric Microwave Oven
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
