Question about Car Audio & Video
Pioneer TS-W306 subwoofer vented enclosure to fit golf mk1
2 Suggested Answers
SOURCE: ts-wx105a pioneer subwoofer connection to car stereo
1 I 2 I 3 I 4 I
---------------------- the wiev from woofer
5 I 6 I 7 I 8 I
1- Right Chanel (-)
2- Right Chanel (+)
3- Left Chanel (-)
4- Left Chanel (+)
5- NC (not connected)
6- GROUND ( - )
7- POSITIVE ( + )
8- Remote (from HU)
Posted on Jul 15, 2009
TS-SWX310 work in 2002 Chevrolet Avalanche
Of course it will fit if you make the hole a bit bigger ,get a proper old time fitter he will make it fit these youngsters are all quickness unit fitters ,no idea how to improvise
Mar 17, 2012 | Pioneer TS-SWX310 Car Subwoofer
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
Hi i have a pioneer subwoofer ts-w2501d4 and i want you to tell me the exact dimensions for a sealed enclosure box!!! thanks regards
1.2 cubic feet, tuned at 32hz - 35hz
this will help you alot trust me.
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
Mar 30, 2010 | Pioneer TS-W2501D4 Car Speaker
I need bow specifications for a pioneer ts-w308f
Hello, The problem with the enclosure is that you purchased a "free-air" sub, which is designed to NOT use an enclosure. You need to simply mount the sub on a baffle (board) that covers the whole entire rear deck of your vehicle, and seperates the inside of the trunk from the cabin of the vehicle. Use sealant to keep the two compartments sealed air-tight and mount the sub on the baffle-board. The other option, is to build a very large box (larger than 3 cubic feet) that would be incredibly huge for the subwoofer, as a free-air, it has a VERY high QTS, and relies on a massive amount of air behind the woofer to allow it to reach low frequencies. The best bet would be to get rid of the free-air sub and purchased a sealed enclosure subwoofer for use in a small (.6-1 cubic foot) sealed box.
Feb 16, 2010 | Car Audio & Video
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Pioneer ts-w3001d4 enclosure box specifications
big red
all you need is about 1 and 1/2 foot deep for relly good bass even better if it is vented
Oct 23, 2009 | Pioneer TS-W3001D4 Car Speaker
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer PremierĀ® TS-SW1241D Car Subwoofer
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Choice of speaker box
If you're looking for SPL (LOUD) go vented.
If you're looking for tonal accuracy (Sound Quality) go sealed.
The tradeoff between the two is that a ported enclosure will allow your subs to play highly powered. More air flow - better cooling of the voicecoils.
Sealed enclosures dont like much power because the coil cannot breathe and heats up rather quickly.
Its up to you, and your listening type.
Just remember LOUD = PORTED
QUALITY = SEALED
Bandpass is kind of a mixture of the two, however you give up some of the frequency range the sub plays at - and I dont ever recommend a bandpass enclosure to my customers unless they are looking to be flashy and light up the cones or magnet assemblies.
There are advantages and disadvantages to every enclosure type.
Pick the one that best suits your taste, and be sure to fire it toward the rear of the vehicle for the best response and cabin gain.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 24, 2009 | Pioneer C-Type TS-W306DVC Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
