Fuse blew now wont switch on
Hotpoint AQ113D697E Aqualtis Steam 11kg fuse blew,replaced fuse now wont switch on
5 Suggested Answers
  • 333 Answers
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Posted on Nov 30, 2008
  • 86 Answers
SOURCE: a hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Posted on Jan 02, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
  • 114 Answers
SOURCE: washing machine door wont open on hotpoint
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Posted on Jun 25, 2011
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Hotpoint aqualtis error code F04
Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Washing Machines
I am looking for a manual for hotpoint aqualtis AQCF 852 BU. Can you help please?
I have the same dryer and went on the Internet and typed "Hotpoint Aqualtis" on Google. One of the alternatives is "Instruction Booklet" This when printed is the Manual for the dryer, in full.
Aug 25, 2011 | Hotpoint Dryers
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
