Question about Dorman 2004 GMC Yukon XL 1500 Seat Heat Pad
Heated seats 2004 gmc - Dorman 2004 GMC Yukon XL 1500 Seat Heat Pad
Fuse for heated seat 2004 GMC Envoy
Rear fuse box , under left back seat ! SEATS circuit breaker B 30amp .
https://www.youtube.com/watch?v=Fhd2DPbTjeE&t=86s
Dec 12, 2016 | GMC Cars & Trucks
2004 GMC Envoy driver's side heated seat quit
I have the same problem except the back of mine works but the bottom doesn't. Passenger side is fine. Let me know what you find out if you could.
Aug 26, 2011 | 2004 GMC Envoy
2004 yukon seats are not working/heated seats not working
Check the fuses, the owners manual should be able to help you there.
Jan 23, 2010 | 2004 GMC Yukon
2005 gmc sierra 2500hd heated seat turns off
you have a couple of problems first of all your drivers sd=ide heated heat pad is probably faulty, for your heating problem you may have to get the hvac doors recalibrated.
Oct 05, 2009 | 2004 GMC Sierra 2500
Heated seats won't stay on in 2004 GMC Yukon Denali
See GM TSB 05-08-143-001, If you have Adjustable pedals, especially if they don't work with the memeory buttons, but function with thier own buttons. Its the Brake Pedal Position Sensor is shorted and mesing up the seat module which controls the heaters too. My 05 Suburban had the same issue
Jan 30, 2009 | 2001 GMC Yukon Denali
Heated seats not working.
Work for a GM dealership. the problem is the heated seat pad element is bad. Replacing the element is not easy but can be done at home.
Jan 29, 2009 | 2004 GMC Envoy
I dont know how to turn the heated seats on?
locate the heated seat button and the heated seat should start to work
Jan 17, 2009 | 2004 GMC Envoy
2004 GMC Envoy Seat Heating Element
Yes u must de-trim the seat cushion, the element is inside the seat, this is not a job for the novice, get the part yourself and take it to an automotive trim shop.
Dec 09, 2008 | 2004 GMC Envoy
Dorman 2004 GMC Yukon XL 1500 Seat Heat Pad Logo
67 people viewed this question
Top Dorman Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Dorman Wine and Spirit Expert? Answer questions, earn points and help others
