Question about Samsung DV448AEE Electric Dryer
It says to clean filter, but filter is clean and it will still not start
It says to clean filter, but filter is clean and still will not start.
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
Cleaned my filter out now it will not pump,never had a problem till now
Once shut to clean the propeller needs to be cleaned as it gets clogged. You need to pull out the piece housing the propeller and rinse off or use a thin item to wash out any debris stuck.
Sep 17, 2013 | Tetra FS3060 Power Filter
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
What is the proper equipment to use in vacuum filter cleanng?
I have blown out filters with presure hoses and I have washed filters, both ways will clean them. they say once a filter has been cleaned it will start to lose its effectiveness. Clean till you can buy new ones.
Oct 24, 2009 | Vacuums
Lg tdc70040e I have this dryer. I dont start
Make sure the exhaust vent line is not clogged. Check the entire length all the way to the outlet.
Jul 19, 2009 | Dryers
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Hard starting.. check engine on P0101
Replace the filter but don't try and clean the MAF sensor,Just replace it.
May 09, 2009 | Nissan Maxima Cars & Trucks
Samsung DV448AEE Electric Dryer Logo
19 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
