Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Drive wont mount, blue light flashes - IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
  • 93 Answers
I had a similar problem. I found out for me I had to many HDD's.
Once I disconnected the other HDD's (except C: drive) I was able to initialize it. Let me know if this works for you.
Posted on Jun 16, 2014
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
WB 1TB blu light flashes but wont startup
The my book world has 3 different kinds of flashes.
1. Fast flashing (every 3 seconds) - Which means it's going into standby mode.
2. Slow flashing (every 5 seconds) - Which means it's in standby mode.
3. Alternative flashing between inner and outer ring - Means RAID failure (this only applies if you have the RAID compatible version [dual drive my book world])
4. Simultaneous flashing - Means the drive is overheating and the drive needs to be shut down.
Try resetting the drive, using the link below for guidance (this will not effect your data). If the drive does power-up, you will need to change the IP to static, if you had it that way before and you will need to login with the following login details: Username: admin | Password: 123456
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1521&p_created=1172595028&p_sid=UhG4a-Sj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0xNTIx&p_li=&p_topview=1
Jan 19, 2010 | Western Digital 500GB My Book World...
Drive won't mount
The Blue and Red lights generally indicate a harware failure. If the failure is power supply or enclosure you can simply solve the issue by taking your drive to a PC shop and having the techs there remove the hard drive inside it and move the hard drive into a new enclosure. Once in the new enclosure have them test it to see if it works. If it does buy the enclosure and be back to your business, if that fails you will need the help of a data recovery pro to retrieve your data(assuming there's anything worth saving). If this is the case, the transfer fails and you need your data back, reply with your location(Country, State and City) and I will be happy to direct you to an appropriate facility to have your data recovered.
Hope this helps FixYa,
Chris
Sep 24, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
Same wont mount
this is hot-connecting, so it should, could be your sys, try restarting or another usb port. Go to drives and manually connect.
Jun 09, 2009 | Verbatim SmartDisk Firelite Portable USB...
Flashing blue lights on the front
check the hard drive connects
Apr 20, 2009 | Computers & Internet
Firelite USBFLB 160 won't mount
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Feb 16, 2008 | FireLite (USBFLB80) Hard Drive
Communication between hard drives
Flashing light on enclosures  usually means the drive is being read, written to, or mounting.
Oct 27, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Blue power light is flashing red and the hard drive won't mount
Hi Vieve, The manual says nothing about flashing red and blue nor could I find anything of any real substance. Basically this thing is a box containing an IDE hard drive and some electronics that interfaces the drive with firewire, power distribution and a few other odds and ends. I suspect the board that contains the electronics may be damaged, however, its entirely possible that this may be some undocumented error that can be reset. I would try calling the vendors tech support, it?s at least worth a shot. If getting your data off is the concern it might be worth your time to buy another enclosure, install your drive and plug it into your Mac. There is a good chance your data is recoverable. Sorry I couldn?t get you a more definitive answer.
Jan 11, 2007 | OEM Systems Ice Cube 3.5 inches FireWire...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
87 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
David Payne
David Payne
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
