Question about Brother PE770 Computerized Sewing Machine
Brother pe 770 F04 Foot controller break
Error message when machine is turned on
    Top Expert:
  • Brother Master
  • 10,875 Answers
Brother pe 770 F04 Foot controller break - 23490158-3kkicvrcy1b042zi1mnwfdoh-1-0.png
Posted on May 28, 2015
  • 980 Answers
SOURCE: SETTING THE TIMING ON DISNEY BROTHER PE-180D EMBROIDERY MACHINE
Email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Mar 07, 2010
Testimonial: "although this was very helpful i decided to take it to a shop and let them sort it out thanks for the help"
  • 2069 Answers
SOURCE: Brother 770-PE I have Amazing Design software and
well, from what is indicated in the USB manual for your Brother, check that none of the below issues is causing this.
- Ensure that USB media contains data for no more than 200 embroidery patterns since Embroidery patterns cannot be transferred to the machine if the USB media contains data for more than 200 embroidery patterns. If this is the case, reduce the number of designs saved on the USB media.
- if the embroidery designs contain too many colors (this number may vary within the designs themselves), it may not be possible to transfer an embroidery pattern to the machine, even if there are less than 200 embroidery patterns that have been saved on the USB media. In this case also, reduce the number of designs saved on the USB media.
- Save the patterns in the root directory of the USB media. If embroidery data is saved in a folder on USB media, that embroidery data cannot be retrieved by the machine.
thanks for using fixya
Posted on May 27, 2011
app_3rp12471
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Posted on Jan 09, 2012
  • 12 Answers
SOURCE: brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
Posted on Jul 05, 2012
  • 12 Answers
SOURCE: How to oil brother PE 770
Brother says it should not be oiled but having 14 of those, I know that it has to be done but a Brother technician will not do that. OILING the machine may cause F05 speed sensor error. See how to solve it under this label.
U need to remove the complete front plastic panel. 3 screws on the top (2 lower the handles, 1 at upper right. Remove 1 screw at the center bottom of the rear panel. Remove both left top/ bottom panels (1 screw each) then the horizontal bottom left panle (2 screws). All the balance is fixed with clips.
First undo the 2 clips under the machine than carefully unclip everywhere. Front panel have 2 wire assembly attached to main board. Regular one is easy to remove. To remove the flat one, send down the upper part of the attchment on the main board.
Don't use reg. thin white sewing machine oil, it evaporate. Use SAE 80 (differentail type) oil or something like taht. Lubrificate all 4 lower shaft supports, rotary hook gears and central pin (from the top, under the bobbin case). Then lubrificate all the upper shaf support and especially all the needle bar mechanism. U need a good light to see upper needle bar support. Lower needle bar support support is the most critical point.
Posted on Jul 07, 2012
Brother pe 770 brand new with this error message F02 SS SW ON
Brand new? Take it back where you bought it. It is a defective unit.
Mar 01, 2017 | Brother PE-770 Embroidery Machine
My CS 770 displays a flashing F4 Brother sewing machine
Perhaps this will help:
https://answers.yahoo.com/question/index?qid=20120713084921AAH7Vxl
Not much information on a Brother C4 error. You might try contacting Brother Support. Support Center
Jun 13, 2016 | Brother PE770 PE 770 Embroidery Machine w/...
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
Mar 13, 2016 | Brother Sewing Machines
How do I correct an erroneous "raise presser foot lever" message?
I would say it time to have the computer or sensors of the machine checked
Jun 04, 2015 | Brother PE-770 Embroidery Machine
My Brother PE-770 presser foot Q has started making a clacking noise. If I press in on the lever on the back of the foot, the clacking stops. What is causing this loud noise and how do it fix it?
Sounds like something in the machine in the head that makes it go up and down. either wear or something loose. I would have it checked by a Brothers repair shop
Jan 10, 2015 | Brother PE-770 Embroidery Machine
My machine shows FO4 message and none of the buttons are working for this message.
There are 2 things that cause the F04 error.
1 - Wrong foot control: If you have 2 machines, you might have them mixed up between machines.
2 - Burned out foot control.
Bring the machine to a Brother shop; try the new foot control on your machine before you buy it.
The part number is XC7290051
Alternative Part Numbers Include XC6651321, XC6651221, XC6651121, XA3931051, XC1154051 & XC6651051
Apr 16, 2012 | Brother SE-270D Computerized Sewing...
Nx400 error message F04?
I had the problem with the error code F04 and found out that it is your foot pedal for the machine. Unplug it and it should start right up as ours did.You will need to fix or buy a new foot pedal. When they repair and or clean your machine they don't use your foot pedal but they use their own so they will miss the broken foot pedal.
I hope this helps you.
Bob
Jan 19, 2011 | Brother NX-400
Fo4--What does it mean and where do I find the translations?
F04 is foot control error. It is probably a bad foot control, but it may be the plug in on the machine or a circuit board.
You can run the machine without a foot control for now; just unplug the foot control from the machine and use the Start/Stop button like you would when embroidering.
Before replacing the foot control, you should bring the machine to a Brother shop and try a new control. If the new one works, then the control was the problem.
Aug 03, 2008 | Brother SE-270D Computerized Sewing...
Brother PE770 Computerized Sewing Machine Logo
1,164 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
