Question about Mitsubishi WD-82738 DLP TV
Replacde lamp but now screen is flashing - Mitsubishi WD-82738 DLP TV
How do I fix fuel gage on 1999 Blazer
The sending unit is bad. Some cars need the fuel pump replacd. May b easier to just record ur miles
Jun 22, 2015 | Ipcw Chevrolet Blazer Midsize 1998 1999...
Heard a pop and picture went black ,no audio .lamp has never been replaced.
You need a new picture tube. The same thing happened to my tv. My audio went out also but for some reason when the tube was replacd it fixed the problem. The tubs are about 200.00
Nov 13, 2010 | Sony KDF-E55A20 55 in. LCD Television
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
I replaced bulb on pt60lc13 and did steps to reset timer, however screen won't come on so don't know if it reset. Power button flashes for about a minute then flashes red continuously. Lamp light flashes...
Make sure that your lamp is install correctely or that the door closed properly. After a proper lamp installation you should get a blue screen with a sign prompting you to reset lamp timer, follow up instructions and reset it.
Sep 24, 2009 | Televison & Video
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Mitsubishi WD-82738 DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
