Question about SanDisk Sansa e260 MP3 Player
Continued Lost Memory...
So, I've been having some trouble with my 4GB Sansa e260 MP3 player for a while now. To start off, my music files have been disappearing and/or turning into "bad tracks" for a while now. I've learn to fix that problem by formatting it. So far, I've had to do it three times and it helped. Buuut... The last time I updated it with some new songs, the memory on it can never seem to hold my last settings and when I start it up, it always goes directly to the language set up when I know it was last at english when I last turned it off. Same with all the other settings. Anyways, I thought if I formatted it yet again, it would solve itself... Nope, that didn't happen. When I finally finished putting all the songs back on it, I turned it on and the same thing happened, and, I have no songs either... But when I hook it back up to my computer and check in the files, it says all the music is on there...
I really like this MP3 player a lot, and don't really consider getting a different kind, but all these troubles I've been running into constantly is starting to really piss me off. Also, when I bought it I forgot to get it under the store warranty and I'm not sure if I can exchange it. Any and all help would be kindly considered. If you have any suggestions or help, please contact me at kyrians-hope@hotmail.com.
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
How do I get music onto the MicroSD?
Jan 21, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
Can't delete video files from Sansa MP3 player
There's actually another mode, MTP. Files in this mode won't show up in the other mode.
Jan 16, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk mp3 player e260
there web site has driver downloads just download the sansa media converter
Jun 01, 2008 | SanDisk Sansa e260 MP3 Player
Recovery Mode, Updated Firmware... Memory Capacity Deleted!!!
It probably changed the mode of the player to MTP instead of MSC. There is a setting in the mp3 player for that.
let us know if it helps.
Dec 21, 2007 | SanDisk Sansa e260 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
