Question about Husqvarna Huskystar 215 Sewing Machine
Need bobbins where can buy bobbins
Janome Memory Craft 7700qcp looking to buy more bobbins. Is their any difference between bobbin item# 200-122-005 and item# 200-122-647?
You need to check the specifications to see if your machine model is listed for the particular bobbins. If not, then don't buy them.
FWIW, it appears your machine takes Class 15 plastic bobbins, which should be easy to find at the local Janome shop, fabric store...or order online:
Class 15 Plastic Bobbins 10pk
Nov 09, 2017 | Janome Sewing Machines
Can you tell me what size of bobbin to use for the model 416? I bought it used, but need more bobbins!
Take the bobbin you have to the local fabric store or a sewing machine shop and ask them to help you find the right bobbin for your machine. Buy only one package to start so you are sure they will work before you buy more.
Jul 09, 2015 | Euro-Pro Sewing Machines
What bobbins fit the singer featherweight 117
The Featherweight II 117 uses the Class 15 bobbin. A 4-pack of the Dritz equivalent of the bobbin is available from Amazon here: http://www.amazon.com/Dritz-Plastic-Class-15-Bobbins/dp/B000Y3D1NG . Singer has a 10-pack of the bobbins here: http://www.singerco.com/accessories/detail/2075/class-15-bobbins-10-pack . You can buy a manual from Singer, as well. (See their Instruction Manual page from the Customer Support Link then enter 117 in the Search box.)
I hope this helps.
Sep 07, 2011 | Singer Featherweight II 117
I need to know how to reset the bottom tension. Mine is loose. I don't have my manual with me - HELP= it is a 7570
A good way to set bobbin tension.
Thread bobbin.
Hold bobbin buy the thread.
You should be able to hold the bobbin up buy the "pig tail" thread and the bobbin should not fall to the ground.
You should be able to give it a good shake and it drop about 2-4 inces.
Are you having looping on the underside of the fabric, if so this will not fix this problem.
If that is the case let me know and ill post a exp for how to fix that.
hope this helps
Mar 30, 2011 | PfaFF Creative 7570
Which bobbin do I buy for the baby loc ellure embroidery machine?
if you go to the store to buy a bobbins, just asked the bobbins for your baby loc machine, if there is a # of your machine just present it. dont buy a bobbins for high speed machine, co'z it is deferent to your machine
Mar 26, 2010 | Baby Lock Ellure
Help I need some bobbin cases
If you need bobbin cases you must buy the Bernina bobbin case, if you need bobbins you can buy them anywhere even on ebay
Feb 26, 2010 | Bernina Activa 140
I NEED BUY THE BOBBIN CASE XL 3750 BROTHER SEWING
No problem, go to a Brother repair shop and buy one.
Feb 11, 2010 | Brother XL3750 Mechanical Sewing Machine
BOBBIN
hi there do you mean the bobbin race or just the plastic bobbins
both are avaliable from janome direct also plastic bobbins avaliable easily from any sewing store selling janome accessories or try e bay mary h
Dec 19, 2008 | Janome Memory Craft 9000 Computerized...
Husqvarna Huskystar 215 Sewing Machine Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
