Question about Sony KDS-R50XBR1 50" HDTV
Tv lamp replacement
I have a Sony Projection tv and i need to replace the the lamp,my manual only tells me how to get the houseing out of the tv and how to put it back into the tv,i need to know how to get the lamp out of the houseing and how to put the new lamp in.
  • JANNIEB May 15, 2008
  • Anonymous Jun 04, 2008
    how do i get the lamp oujt
I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
I just replaced the lamp and saved $130.
I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
re-attach all the screws and slide it back in.
It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
Posted on Dec 05, 2007
  1. DLP TV Replacement Lamps -‎‎Contact Us Factory Trained Customer Service
    Same Day UPS Shipping
  2. Testimonials
    Serving the Industry for 10 Years
    The Original Replacement Lamp Co.
Search Results
    Rear Projection TV Replacement Lamps: Electronics > ... > TV Accessories & Parts, Inc.Results 1 - 24 of 10958 - Online shopping for Rear Projection TV Replacement Lampsfrom a great selection at Electronics Store.
    SONY KDF-E42A10 TV Replacement Lamp with Housing, Inc.
Jan 07, 2016 | Televison & Video
My Sony LCD rear projection tv model KDF-55WF655 won't come on. Instead the red lamp light comes on. What can I do ?
Red lamp light indicates that tv needs lamp replacement as existing lamp in tv is dead/ broke.
Lamp replacement procedure is written in user manual of tv.
Apr 28, 2011 | Sony Televison & Video
Sony Wega television has a red light flashing that says lamp
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
May 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Sony Wega 55 inch, won't turn on and displays shows lamp problem? How do I resolve this? Thanks
    Please replace lamp in TV and lamp replacement procedure is written in user manual of TV.
    Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
    Need further info, let me know with model number of Sony TV.
    Apr 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Lamp Replacement on Sony Wega TV
    Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
    Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Is your TV still under warranty? If it is, then you should send it back and let them fix it. If you do it yourself, you might void the warranty.
    Jan 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
    Sony KDS-R50XBR1 50" HDTV Logo
    324 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
