Cars & Trucks Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to start the firing order on the distri butator cap
Dont where to start firing order on the distributator cap, on a 350 motor p/u
Anonymous
Level 3:
President:
  • Master 1,392 Answers
  • Posted on Jun 08, 2009
Anonymous
Master
Level 3:
President:
Answers
1392
Questions
0
Helped
656898
Points
4859
Turn the #1 cylinder to top dead center, on the compression stroke. Remove the cap and see where the rotor button is pointed. This is the #1 cylinder plug wire position. Start from here, and clockwise run 1-8-4-3-6-5-7-2.
I need the firing order on a 72 Buick Skylark 350 front motor Distributer
Firing order is usually found on an inlet or exhaust manifold. Take off dizzy cap and turn the engine to identify rotation direction then from #1 follow the sequence.
Firing order 3.0 mitsubishi
Never seen firing order of123456.
You should be able to find firing order with web search.
Chevy 350 firing order diagrams
1-8-4-3-6-5-7-2
TDC on #1 compression stroke,not exhaust
Number 1 on the dist cap-- is at about 7 o clock,
as you face the motor from the front
2-4-6-8
1-3-5-7
1&2 are at the front-- as you face it
1helpful
2answers
I mixed the distributor cables up,so i need the order to correctly connect
If the wires are still in the distributer, AND, if you have a stock intake manifold, the firing order is on the manifold. If it's a V-8, the number 1, 3, 5, & 7 plugs are on the drivers side of the engine. The number 2, 4, 6, & 8 plugs are on the passenger side. The number 1 plug wire can be located by looking at the distributer from the front of the engine and visually looking between the distributer and the number 1 plug. Visualize the distributer as a clock. The number one position should be located between 4 and 5 o'clock and should have the longest wire of those on that side of the distributer.
If the wires have been pulled from the distributer, then, then, remove the rotor cap, turn the engine over slowly until the rotor is pointing to the number 1 plug. Using the firing order on the intake manifold, starting with number 1, replace the wires going clockwise around the distributer.
1helpful
Firing order ford 300 six and #1 position on distributer cap 1990
THE 300 4.9 ENGINE FIRING ORDER IS 1 5 3 6 2 4 THE NUMBER 1 POSITION ON DISTRIBUTOR CAP IS AT 6 OCLOCK POSITION.
Rough idle and accelleration in my 89 GMC truck with a 350 TBI
Try a new distributer cap and rotor button,these are notorious for wearing out the carbon pick-ups and leaving carbon tracks in the cap which messes up the fireing order.If that does'nt fix it try plugs and wires.
1helpful
2answers
We replaced the distributor cap and rotor on our Dodge Ram Van 1500, but one wire popped off as we were working and we aren't sure they are in the right order anymore. How do we find a diagram to help us...
the firing order is usually stamped on the engine itself. Take off the distributer cap and turn the ignition to see which direction the rotor is turning.
The distributer cap has the number 1 plug marked . After finding the firing order, place the wires 1 where the cap is marked then in the direction the rotor is turning (ie:clockwise or couterclockwise). Keep looking . Most every motor I have seen has the firing order maked right on the engine.Or the owners manual ?
2answers
I have a 1990 dodge dakota. I need to know where #1 is on the distributer cap. I know the firing orders , though i have no markings on the cap as to where #1 starts.
You can rotate the engine until #1 piston is at top dead center when it has the rotor on the distributer will point at the #1 on the cap.
Wire hookup to distributer cap.
Wires just pull out of the top of the cap. Do them one at a time and you won't have a problem putting them back.(they just push into each hole.)
5helpful
2answers
E350 frod van
On your Ford E 350.
Are 3 Engine sizes available. 5.0L, 5.8L and 7.5L.
On Gasoline.
The Firing Order for 5.0L and 7.5L are the same.
But diferent on 5.8L.
Here is a Picture if the firing order and cylinder number.
e911241.jpg tHIS IS THE FIRST FIRING ORDER FOR 5.8L.
The CIRCLE mark is for the cylinder # 1 on the distributor cap.
e0ba3c1.jpg This is for the 5.0L and 7.5L
The Circle mark is for the cylinder # 1 on the distributor cap.
The ROTOR turn Clock wise.
I hope this help on your problem.
Thank you for use fixya......
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
