Question about Philips DVDR980 DVD Recorder
Dvdr 980 Unlock code
How to reset nokia model:RM-975
NOKIA X RM-980 HARD RESET - YouTube
? 2:48
https://www.youtube.com/watch?v=p1MvDSvg0eI
Jun 9, 2014 - Uploaded by ??? ????????? ???????.
NOKIA X RM-980 HARD RESET. ... Como desbloquear NokiaLumia 630 Model:RM-977 Pantalla bloqueada Cricket - Duration: 6:32. by ...
Nokia Lumia 635 - How to unlock security lock by hard reset ...
? 13:59
https://www.youtube.com/watch?v=3HPlTPXQP5k
Sep 22, 2014 - Uploaded by phone reset
Nokia Lumia 635 - How to unlock security lock by hard reset. phone reset ... Unlock AT&T Nokia Lumia 635 (RM-975) - AT&T Unlock Code ..
RM-974/RM-975 - Factory Resets
www.factoryresets.com/.../how-to-hard-reset-nokia-lumia-635-rm.html
Feb 27, 2015 - Before you decide to Hard Reset Nokia Lumia 635 (RM-974/RM-975), please test the following process to repair your mobile. First step charge ...
Dec 03, 2015 | Nokia Cell Phones
My samsoung sgh d 980 sim cod
Hi if you are samsung D980 mobile is asking for sim unlock code the it mean your phone is locked to some other network provider due to this you can't use other network sim in your phone until you unlock it ..You can purchase code from sites like SuperUnlockCodes.com they are rendering unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ....
May 18, 2014 | Samsung SGH-D980 Cell Phone
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
EPSON FX-980 RESET
don´t have reset to unlock paper motor, you need dismoun the motor to check if are damage of are the main board who make the problem, if motor are damage, de spare number are 2019040
Jun 24, 2009 | Epson FX-980 Matrix Printer
980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Nov 19, 2008 | OKI C5800Ldn Led Printer
Unlock codes for philips dvdr 3510
Make sure no disc is loaded
Press on the RC:
0 0 8 6 0 0 0
Done!
May 23, 2008 | Televison & Video
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Apr 15, 2008 | Philips DVDR 3355 DVD Recorder
Unlock Code for Philips DVDR3575H/37
There is a YouTube video that has the secret code. WARNING: it will only work 3 times, and then the code will no longer work.
Mar 27, 2008 | Philips DVDR3575H/37
Philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd player
Just google a bit like
"My brand nad type" region code unlock
You can be surprised - once it was - press 999 on remote :)
Dec 04, 2007 | Televison & Video
Philips DVDR980 DVD Recorder Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
