Question about Motorola Mobility MFV700 Digital Frame w/ Video-In-Picture & Wireless Camera
After powering the camera unit and the photoframe, the photo frame will not connect whit the camera unit
The green indicator light is still blinking
How to add photos in jassop 7'' photoframe
well first install the software into your pc run the cd and install the Image Shuttle.exe file. then plug USB cable end"B" to fram and "A" to pc windows should auto detect and install the required drivers
to import files connect the frame to your pc using the USSB cable open IMAGESHUTLE program check if it detects your frame using folder browser find the pics you want to add highlight the pic and click ADD once done choosing your pics click the TRNASFER button
hope that helps....
Jul 12, 2011 | PANDIGITAL 7" Digital Photo Frame With...
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
My digital photo frame screen is black. I have checked the AC adaptor on another frame that I bought at the same time and it is transmitting current. It is a smartparts frame SP1000EF, Model no....
It tends to be the problem of internal circuit board in digital photo frame .If the adaptor is working fine with other digital photo frame then definitely it is problem of internal connection . So better replace the unit if it is under warranty . Else one more try is just tap on the sides of photoframe when you power on the unit .
Hope this helps .
Apr 22, 2010 | Smart Parts Digital Picture Frame
Where can a get a power adapter for my 10 inch digital photo frame that was lost? do you know the part number
Bring the photo frame to Radioshack. They have a large selection of universal adapters and can help you get one with the correct size tip and voltage.
Feb 27, 2010 | Philips PhotoFrame -10 Digital Picture...
Downloading pictures from pc to photoframe
First install the application which you receive with the picture frame on your computer. Connect the frame with your computer by using the USB cable. Once you have connected the frame, you will be able to see an additional drive in "My Computer". Just copy the pictures from your computer and save them in that new folder.
In some software, which come with the digital frames will create a program by themselves after the installation. In these case, you need to open the program and then connect the photo frame to the computer. After connecting, you will see that the frame will synchronize with the computer and you will see that the program which you have already opened will show you the drive of the frame, where you can just transfer the pictures from your PC to the frame.
Jan 28, 2009 | Philips PhotoFrame -10 Digital Picture...
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Copy photos from pc
Look for an option when you open photo manager that says upload picture. Browse the locations then choose my computer, pictuers and click open the picture that you want in photo manager. Other wise, try to put/copy the picture in a new folder in you computer, then click cut and paste to photo manager.
Artgirl
Jul 20, 2008 | Philips 9FF2M4 9" Digital Picture Frame,...
I bought a photoframe-10FF2 series. I have a pc with lot of pictures-I want to transfer them--I have not been able to-please help
My philips Photo Frame does not work. It just get the "Please Wait" message when I start the photo frame. But nothing happens after that. Can someone help me please. I have reset the button, but nothing happens.
Thank you much...
May 16, 2008 | Philips PhotoFrame -10 Digital Picture...
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Motorola Mobility MFV700 Digital Frame w/ Video-In-Picture & Wireless Camera Logo
50 people viewed this question
Top Motorola Mobility Photography Experts
Tony
Are you a Motorola Mobility Photography Expert? Answer questions, earn points and help others
