Question about Samsung 43 PN43D450A2D Plasma TV
How to reset plashma tv 43 inch - Samsung 43 PN43D450A2D Plasma TV
I have a Toshiba 43 inch projection TV. Six months ago the convergance function was repaired by a TV repairman. Now the TV is periodically turning on and off by itself while we are watching it. What...
More than likely, as the tuning is governed by a remote control function, it is a dodgy remote control.
Try putting the remote control out of the room.
Hope this helps.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
For about 4 weeks in have been getting a notice when I turn the tv on about a lamp timer needed to be reset. While the TV was on it cut off by itself. This is a panasonic 43" rear projection LCD TV. It is...
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
This is the procedure for resetting the lamp timer. Have you ever replaced the lamp before? The lamps usually never last 5yrs.
Sep 30, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Connection problem
You can connect via a coax cable from the sat. box to VHF input of your TV and tune on ch 3 or 4 or connect via a RGB cable to component input of your TV or a regular Audio/Video composite cable will connect sat. receiver to your TV use yellow color for video and red&white for stereo Audio then choos the connected input on the menue and watch sat.
May 27, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hdmi cable location???
Click HERE to see HDMI Jack image, if it is there at back of TV then OK and if do not, then TV has No HDMI facility.
Apr 28, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Help with my tv
I don't know what you mean by "good". I've worked on this set several times for different problems. What do you need ?
Dec 02, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
My tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Jul 24, 2007 | iLO 3200 32 in. LCD Television
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Samsung 43 PN43D450A2D Plasma TV Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
