Potterton Statesman about 10 years old won't start
Boiler stopped working, pressed button, starts for a while then goes off. Had engineer in, he said it was a problem with the tank and fitted another pipe that comes out the top of the tank, this has something else attached to it before it gets to the boiler. Tried to get oil out of the pipe inside where the boiler is, nothing coming out, so tried to **** oil through, the pipe is ok but where this small device is (with a button on it) the oil doesn't come through very well when it's attached back on the pipe, is this causing the problem, it was a temporary fix but if this is now another problem with oil flow what do I do. Anyone to help please. Thanks.
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Hi. We recently moved to a rented property. We
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Posted on Nov 13, 2009
SOURCE: potterton statesman utility boiler making
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Posted on Feb 28, 2010
  • 3315 Answers
SOURCE: Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Posted on Nov 25, 2012
SOURCE: Potterton oil boiler won't start
check filter is not restricting flow due to clogging an check oil nozzel this might be worn. also check majic eye is not clogged wipe clean when did you last service
Posted on Feb 12, 2014
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Feb 12, 2014 | Cars & Trucks
Hi. We have a potterton netaheat profile boiler and the pressure has dropped so low nothing will work. I know it needs to be recharged but don't know how to do it. The only visible pipes are on the top...
The cold water feed to the boiler is where you will find the refill point which should be at the base of the boiler where all the pipes come in
Oct 06, 2017 | Water Heaters
Need Manual
Nov 24, 2012 | Heating & Cooling
Potterton statesman oil central heating boiler the household oil ran out and i had it refilled and now the lock out button is illuminated i believe i have to press the burner reset button but not sure...
Hello my name is Heath it will be my pleasure to assist you. You will have to push and hold the reset in on the side of the control for 15 seconds. But you will also have to bleed the air from the system from the 3/8 nipple on the lower left side once the lockout has been released and the motor starts.
Sep 05, 2010 | Heating & Cooling
Potterton statesman utility boiler making screaching noise for 20 mins on start up then stops screaching and runs quietly!!!
Thanks for a reply
Feb 18, 2010 | Heating & Cooling
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
Nov 13, 2009 | Honeywell Electronic Programmable...
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
