Question about Durabrand Audio Players & Recorders
Player reads DVD as bad
Some DVD's work, some do not. Brand new DVD even does not work. What happens is first I put the DVD into the player. The Display window on the DVD player will read as the DVD is loading. The DVD player will continue to try loading it for maybe a minute. Then the DVD player's display window will read "BAD".
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 96 Answers
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Posted on Jan 02, 2018
SOURCE:
SOURCE: Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Posted on Jun 20, 2007
shanth
  • 108 Answers
SOURCE: My DVD player no longer plays original dvd's - only copied dvd's
some times when you create DVD movies by high speed DVD writers, your data cannot be read by dvd player with high performance. it s due to speed mismatching. always write DVDs with Normal speed in order to use with DVD players. while in case oof PC-DVD -Rom it does not happens. it can read any high speed wriiten DVDs. DVD-Rom in PC are more precise than DVD players. Some times Weak DVD player Lens system can also mis read.
Posted on Dec 22, 2007
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
SOURCE: panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Posted on Aug 25, 2008
farr64
  • 121 Answers
SOURCE: DVD WONT PLAY...DISPLAY SAYS READING
try a cleaning disc or clean the laser .could be just a bit of dust..good luck .farr64
Posted on Apr 29, 2009
Lt-32d200
What you are describing is a bad/damaged optical unit in the player--some are sold but only as a complete unit.
Mar 20, 2012 | JVC LT-32D200 LCD TV
Samsung DVD-V6800 combo wont read any DVD's
When you put disc in dvd player tray, optical laser got initialized automatically and all previous data in memory of player erased.
You should not worried about laser movement because its control by servo section of dvd player circuitry.
Kindly contact Samsung to provide warranty cover of your newly player.
Need further info, let me know please.
Oct 27, 2008 | Samsung DVD-V6700 DVD Player/VCR
"Bad Disc" message when reading a disc with JPEG files
Hi
Similar Issue happen to one of my client what we have done is putting the JPEG files into folders (Not Subfolder). It worked well however some JPEG images being skipped if the size is unusual. JPEG images will appear as tracks. Hope this will be helpful. If issue persist please post once more. Also let me know if WMA files are being played.
Good Luck
Jan 24, 2008 | Onkyo DV-CP704 DVD Player
Our DVD player stops several time during a movie. This even happens on new movies. What can we do about this?
Tries websites like Amazon.com,Ebay.com buy a set that call a DVD or CD disc laser eye cleaner.Used it might help.If still happening than the laser eye itself it is dying and to be dead soon.DVD players that are having laser eyes are dying or don't read DVD or CD disc like say no disc all the time.Are not repairable except replaced the whole laser eye data's reader itself not practical,because u can a whole new basic DVD player just the same prices or even cheaper.These day a basic DVD players u can buy it like $40 brand new at any major box retailers stores like Walmart,Target..extra.
Sep 03, 2011 | Dynex DXUPDVD2 Player
Brand new dvds stop working in divd player
You may need a new DVD drive. Find out about it here, or maybe just a firmware update:
http://homeavi.pro-forums.com/
Jun 18, 2010 | Bose Lifestyle 38 System
DVD goes in and tries to start twice then says "no disc". What do I do to fix it?
Just a couple of questions.
1.) How old is the DVD Player?
2.) What is the brand of DVD Player?
3.) Does it do this for all DVD's or a specific DVD?
4.) Has anything changed in the last week or so?
If the DVD player is less than a year old it most likely has a Manufacturer warranty. Also if you haven't tried already try putting another disk in the dvd player and see if it will read it. If it won't read another DVD try a CD.
Please clarify the above so that I may help you further.
Sorry this is happening I know it's frustrating.
Mar 20, 2009 | Televison & Video
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Dvd is not reading
After loading a dvd screen prompts "loading" then "no disc." Even with a brand new disc.
Qaung
Dec 08, 2008 | Philips DVP5140 DVD Player
Dvd player
My worked fine for a 6 months then started reading bad disk even it the disk wasn't.
My solution to problem, buying a more reliable brand.
Apr 01, 2008 | GPX D1816 DVD Player
Top Durabrand Audio Players & Recorders Experts
Steve Allison
Steve Allison
antoniorojas
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
