Question about HP DesignJet 110 Plus InkJet Printer
When I print thereis a strip of textat bottom that doesn't print
    Scholar:
  • 136 Answers
This is easy to take care of. The next time you print a document, look at the print dialog box that pops up and select 90 or 95%. This will shrink the document slightly and all of it will print.
Posted on Apr 15, 2015
  • HP Master
  • 5,631 Answers
As I understand you question youy problem is probably ans incorrect selection of your lower margin or footer or baybe a problem os selecton of pagesige. Es an exapple, this might happen if you formatted your text for size A4 and you are using lellter sized paper.- it won't pring the buttom line.
verify settings.
verify these settings
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
Volume control on rt2370 rca remote doesn't work.
Hi there
I would try going into VOLUME through the MENU and find volume there and set it accordingly.
good luck
Kolbrun
Mar 26, 2012 | RCA Audio Players & Recorders
It wont print anything until i cleaned the nozzles, then i got one line then nothing
Have you tried cleaning the ink cartridges manually? Take a cotton swab and some isoprophyl alcohol and clean the base of the cartridge (Usually a metal strip) It will be a bit messy, so anticipate this, also clean the strip that the ink cartridge contacts within the printer. If that doesn't solve the problem your ink may be partially dried or just about empty.
Aug 28, 2011 | Lexmark X1150 All-In-One InkJet Printer
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
Ever since I did the adobe update, when I print a PDF File on my HPc6180, some prints correctly and the rest prints with random letters and symbols like wingdings. It is just completely random. How do I...
Something is causing the printer to reset and start again. The unintelligible stuff is caused by the printer having lost its setup. The most likely problem is that the printer is losing power. Check the power cord at the printer, at the brick (if it comes apart there) and at the outlet. If you are using a power strip check it. If all seems ok, try plugging the printer into another outlet without a power strip and/or in another room. If that doesn't fix it, more expert help is required by a service person.
May 27, 2011 | HP Photosmart C6180 All-In-One InkJet...
DO I OPEN A STRIP ON THE BOTTOM OF CARTRIGE, OR DO I JUST OPEN THE PACKAGE AND PUT IT IN ? NO INK IS PRINTING OUT AT ALL
Please open the strip and then insert it. This strip will be present in all new catridges in order to avoid dust on the print head nozzles. If the strip is not removed, it can't print.
Sep 05, 2010 | Epson Stylus CX6400 All-In-One InkJet...
When printing, a black stripe is printed on the back side of the printed pages (about 1/4'' wide, running from top to bottom). The ink strip bleeds through to obscure printed side. Any suggestions?
You need to have the exit rollers cleaned at a shop, and a mylar strip added to keep that from happening again. It's the ink from the cleaning station backing up thru the exit rollers.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My daughter pulled this long plastic strip out HP PSC 1210
Sounds like it is the guide strip that pushes/pulls the print carriage back and forth?
Sorry but it is not a repair easily carried out at home, if at all. If in one piece and not broken it might be re-introduced but the bottom line is you will most likely have to purchase new? Sorry. it might cost just as much if taken to a repairs?
Nov 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
My printout looks streaky and fades to nothing toward the bottom of the page. Also some of the text has an absence of ink in a line through the middle of the text.
Clean print heads and encoder strip (clear plastic strip behind print head) with alcohol free window cleaner and some q tips
Oct 09, 2009 | HP DeskJet 845c Printer
HP DesignJet 110 Plus InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
