Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub c253 hdd damage - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,680 Answers
Check for a local dealership
Posted on Jan 18, 2016
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
SOURCE: What does the errorcode C-3723 on a Konica minolta
C3723: Fusing abnormally high temperature detection (pressurizing side)
Posted on Aug 23, 2009
SOURCE: howto fix internal error c - 1183 on bizhub c253
C-1183 - Finishing option elevator drive malfunction
  • 51 Answers
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Posted on Oct 09, 2009
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
How do I replace the fusing unit in Konica Minolta bizhub C253
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Apr 11, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub c253
will require install kit do you have that and the hard drive kit to seperate kits
Feb 12, 2014 | Konica Minolta bizhub C351 All-In-One...
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
What is error c-2527 of konica minolta bizhub c253
sorry, cannot find that error code in SM. Are u sure is it correct code?
Jun 28, 2013 | Konica Minolta Bizhub C253 Copier
Konica Minolta bizhub C253 - Displaying status on a webpage
the hp web jetadmin is quite good, it displays whatever info you select. use version 10.2
Mar 31, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
