Question about Brother HL-2130 monochrome laser printer USB Cable A male / B m
Hp brother printer burning smell coming from fan
Help me with scanner error 8 0n HP laser jet 2727nf
This unit is dead and not worth fixing. That error indicates that the formatter has failed and when that happens it burns the drive motor in the scanner out. Open the top and smell near the narrow slit of glass and you will smell burned electrical smell.
Oct 19, 2016 | HP LaserJet 2727NFS All-In-One Printer
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Loud noise burning smell
please describe the noise? Burning smell like plastic?
It's a laser printer, so it's possible that the fuser is an issue. Is there a paper jam in the printer under the fuser?
Jul 17, 2014 | Brother MFC-8440 All-In-One Laser Printer
Burning smell when plugged in
Perhaps the circuit board is shorted. Repair is not worth it. Burning smell usually kills the systems. Go for a new one.
Mar 20, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Fridge has a burning smell
Are the coils clean by the compressor?
Nov 26, 2012 | Frigidaire FRS23R4A Side by Side...
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
HP 4500 Burning smell
The cost to replace the power board may not be worth it, besides this power board could have damaged some other printer electronics.
If it was me I would put my money towards a new printer.
Sep 21, 2012 | HEWLETT-PACKARD HP 4500 All In One Printer...
I just bought a 1996 camry and the fan sounds loud and it smells like something is burning, yet the temperture is normal and no smoke comes out. Is that Normal? First Toyota, so I"m not sure if the...
Check the fan on broken blades - even a small part missing can cause unusual sounds. If parts are new / serviced - smell can be due to labels getting hot and emitting slight burning smell. Classic are exhaust pipes with partnumber labels left on there. If he smell stays, something in the interior might come from a crash car which was partly burned.
Jun 30, 2011 | 1996 Toyota Camry
Smells like burning oil. radiator fan not coming
you may be loseing a ground. valv coverleaking oil one time a lady had a plastic bag stuck to her muffler.pu
Jan 25, 2010 | 2005 Suzuki Reno
Brother HL-2130 monochrome laser printer USB Cable A male / B m Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
