Question about OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier
Oki es7411 fatal error 928 - OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
  • 97 Answers
SOURCE: fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Posted on Dec 08, 2008
SOURCE: OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Posted on Mar 05, 2009
copiersplusw
  • 136 Answers
SOURCE: fatal error 928 Oki C5500
Open the Unit Up, the Button on the Side opens the Printer. In the rear of the Printer you will notice the Element in the rear of the Printer.
It is usually hot. Well there is latches
as an Authorized Okidata Service Provider I believe these "TABS" should be the color of BLUE. release the tabs and the entire fuser come out just grab the handle that usually comes equipped with the fuser , it is usuallyon top just grap ir and lift it out. Install the New One and your Done.
Posted on Sep 13, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
OKI C711 928:fatal error
Just to confirm that Jeff Hughes is correct. 928 does refer to paper wrapped around the fuser rollers making the thermistor see nothing hence the 928. If there is no paper in the fuser then it will need to be replaced. Remember to turn the machine off when removing or replacing the fuser.
Nov 09, 2016 | OKI Office Equipment & Supplies
Error fatal 928 how to fixe it
Error 928: Fuser Motor Lock Error An error was detected with Fuser Motor rotation by overload. If rebooting the machine does not improve the symptom, you need to check the Fuser Unit.
Sep 09, 2014 | Oki Data Americas, Inc. OKI C 711n -...
928 fatal error
Thons is an issue with your computer (Windows right?)Try To do a registry cleaning with a free registry cleaner.
Aug 15, 2014 | Oki Electric Industry Okidata MC860 MFP...
928 FATAL ERROR
Fuser Motor Lock Error The fuser is not operating properly
Check to confirm that the fuser
is in position.
Replace the fuser.
Replace the fuser motor.
Jun 06, 2014 | OKI C5100n Laser Printer
Oki printer MC860 is displaying fatal error 928. What does this mean
This is a fuser motor lock error. Check that the fuser is installed normally. You may need to replace the fuser unit or the fuser
motor.
Dec 03, 2013 | Oki Electric Industry MC860 AllInOne Led...
Printer OKI C5650: "POWER OFF/ON 928:FATAL ERROR"
TRY REMOVING ALL CONNECTIONS & THEN RESTART.REMOVE CATRIDGE AND RECONNECT
Sep 24, 2010 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 928 Oki C5500
Sep 12, 2009 | OKI C5500n Laser Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier Logo
132 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
