Question about Fenix LD20 Standard Flashlight
My fenix ld10 torch won't work - Fenix LD20 Standard Flashlight
Can you open the switch end of fenix hl21?
the plastic will break and even if you do get access to that, the issue with the corrosion will still cause problems.
Nov 24, 2013 | Fenix Flashlights Black HL21 Fenix HL21...
Back to the drawing board You guys almost got us killed (papajoe480@yahoo.com) I won't hold my breath for your response
in most cases you can here it when the key is turned on you could do a pressure test if you know someone with a tester or a garage does not charge to much to test it
Jan 24, 2013 | Garmin fenix - GPS receiver
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
Fenix hp11 headlight
Hi, I have some experience with this unbekievable good headlight(when it works).
I had a hp10 what started to stop more and more.
After a while it wasn't going on.
5 years warrenty, so i got a new one, the new model.hp11
The main problem is the wire from battery case and the head led.
When there a litte damage inside this wire, light goes of not going on it selfs when it connecting again. After a while it will not work any more.
(if you have a welding station you fix it your self (battery case,can go open by unscrew the wire entrance.)
Chack battery case if the springs are all still connecting the battery.
If you put in one battery false on there is short cut and al sprigs get so hot they will shrink. And stay in that position..fix that your self or ring/ contact the shop you bought it.
There 5 year of garrantie.
wonderfull
Jul 25, 2012 | Fenix Camping, Backpacking & Hiking
I am trying to take off the struts on my 98 Buick Lesabre and the bottom studs won't back off. Are they're any tricks of the trade anyone knows of? I tried soak'n em in WD40 and torching t
if they won`t come out by soaking them or using a torch you may have to put the nut on the bolt so its flush with the end of the bolt and hit it with a big hammer or use a air hammer to move it.not sure where you heated it but heat the strut where the bolt goes through it and you have to use an acetelyne torch not a propane torch as the heat is hotter with a acetelyne torch.be aware that you may have to replace the bolt and nut if damaged.
Apr 02, 2012 | 1998 Buick LeSabre
Rusted wheel bearing won't come off
easiest way is to heat them with a torch 14- 20 dollars at walmart get it good and hot this should loosen nut then try it, you can also SOAK nut with liquid wrench let it set 15 minutes or so spray again in 30 minutes come back and looen nut , get a good pipe to put around wrench for torch
Sep 04, 2011 | 1997 Plymouth Voyager
I HAVE THE APP FOR TRACKBALL LIGHTS, HOW DO U ACTIVATE IT AND GET IT TO WORK?
The Blackberry Torch doesn't have a trackball. OIder Blackberry's used to have it. You won't be able to use the app on the Torch.
May 27, 2011 | RIM BlackBerry Torch Cell Phone
Fenix LD20 Standard Flashlight Logo
29 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
