Question about HP LaserJet 2420dn Printer
Erreur 49,4c02 sur hp laserjet 4250dtn solution
Solution pour l'erreur 49,4c02
swami nathan
  • 208 Answers
SOURCE: looking for a manual
You can download your manual from
www.generalmanual.com/Printers/HP-LaserJet-4250dtn-Printer.htm
Hope my info solves your problem,
Thanx for using fixya.
Posted on Sep 30, 2008
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
SOURCE: I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Posted on Jan 15, 2010
  • 313 Answers
SOURCE: HP laserjet 4250dtn duplex troubleshooting.
replace the duplexer, or clean the duplexer rolls using alchole
Posted on Mar 31, 2010
  • 903 Answers
SOURCE: Can't print on Network LaserJet Printer
If it worked before you updated the driver, go into the Device Manager and roll back the driver to the previous version. Sometimes new drivers haven't been fully tested, or they may contain bugs or may just be incompatible with an application that you happen to be running. If the old driver version works, stick with that.
Posted on May 28, 2010
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
I have HP Laserjet 4250dtn. There is no power comes in. I checked cable, on/off switch, and outlet fine. Is there any power reset or something to turn on printer ? Thanks.
Hi there, Your power supply/board got damaged. There is no way of reseting it as your machine isnt getting power. You will need to take it in for repairs.
regards
Jul 22, 2011 | HP LaserJet 4250dtn Printer
J'ai desinstallé par erreur le
Salut ,
Sauf erreur , c' est du HP ça . Des pilotes sont disponibles ici :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-40706-1
J' espère t' avoir été utile .
Cordialement ,
Dec 19, 2010 | Computers & Internet
Votre site ne me donne pas la main pour telecharger le pilote de l'imprimante hp deskjet 6943
voici le lien pour les pilotes de votre
http://www.howtodrivers.com/model540092.html
?tape par ?tape guide pour l'installation du pilote HP Deskjet 6943. 1. T?l?charger le fichier pour HP Deskjet 6943 ? partir de notre site, enregistrez-le sur votre ordinateur et d?compressez-le. 2. Connectez votre HP Deskjet 6943 ? l'ordinateur. 3. Faites un clic droit sur Poste de travail puis cliquez sur Propri?t?s. Acc?der ? l'onglet Mat?riel. Cliquez pour bouton Gestionnaire de p?riph?riques. 4. Trouvez votre HP 6943 sur Imprimantes cat?gorie double Deskjet nouveau clic sur l'appareil et appuyez sur le bouton R?installer pilote. 5. S?lectionnez Installer ? partir d'un emplacement sp?cifi?, cocher Inclure cet emplacement et cliquez sur le bouton Parcourir pour s?lectionner le Hpdriver cliquez sur Suivant pour continuer, puis cliquez sur le bouton Terminer pour terminer l'installation. 6. Apr?s cette proc?dure, vous devriez voir la nouvelle HP Deskjet 6943 dans la cat?gorie Imprimantes dans le Gestionnaire de p?riph?riques.
Oct 15, 2010 | HP Deskjet 6940 InkJet Printer
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Looking for a manual
Sep 30, 2008 | HP LaserJet 4250dtn Printer
HP LaserJet 2420dn Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
