Question about ASUS B85M-G Micro ATX Intel Motherboard
1 beeb boot - ASUS B85M-G Micro ATX Intel Motherboard
I have a constant beeb beeb ----beeb beeb---beeb beeb from my speakers or headphones but not from the computer tower when the speakers or headphones are removed. Is this a audio problem with PC or a virus?
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
Nov 10, 2014 | Computers & Internet
Boot and work but no beeb
use your software utility coming with your compaq, the administrator utility, and restore to the factory adjustment. and fix it.
God bless you
Oct 22, 2013 | Compaq Presario Notebook
Boot and work fine but no beeb or sound
go to control panel, and use the utility System RESTORE, and put the last days that you know was working Good. and fix it.
God bless you
Oct 22, 2013 | Compaq Computers & Internet
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
It beeps when the computer boots up, sounds like its running , monitor says check your pc. It will ntgo beyond this.
This is a hardware problem like defective ram, cpu or motherboard. Your MB manual gives answers on the sequence of beebs.
Feb 13, 2011 | Systemax Computers & Internet
Long beeb sound
find out what brand your motherboard is and look for the beep codes, each motherboard is different but these beeps are there to tell you the problem. if it isnt turning on when you press the button it is most likely a power supply problem like you said and you should try reconnecting all the power connectors to the motherboard and make sure everything is in place. also look for the voltage switch on the back and make sure it isn't at the wrong voltage that has happened to me more than once ;)
Dec 13, 2008 | Intel Motherboard
The screen stay black on booting computer, it's an acer aspire
plug an external monitor to see if the laptop is booting up at all, it could be the inverter or a memory address problem
good luck
Nov 16, 2008 | Computers & Internet
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
ASUS B85M-G Micro ATX Intel Motherboard Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
