Q- how to rewire hard drive power cord
A. the four (4) wires for the power plug were pulled out. there is a 1-red wire 2-black wires and 1-yellow wire. the sequence is 12 volt, 2-grounds and 1-5 volt. I presume the 2-black wires are "grounds" I think the red wire is 12 volt I think the yellow wire 5 volt when the wires were pulled out the inserts were damaged because when I push a wire into the insert it does not have any resistantance
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
Unless you know what you are doing, just buy another power supply
or, google "pc molex plug" and order a new on with pins, but you'll need a crimp tool for that job.
if you get it wrong, you WILL blow stuff up.
Posted on Apr 21, 2014
xalint1
  • 152 Answers
SOURCE: my comp didnt take my
The red wire should go in the sata connection on the back of the hard drive I have included a picture for a clear view.HERE
Posted on Sep 08, 2008
the logos1
  • 8 Answers
SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
Posted on Apr 01, 2009
bob_computer
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
  • 18 Answers
SOURCE: http://pinouts.ru/Power/atx_v2_pinout.shtml
um what you want lol:?
Posted on Sep 07, 2009
swoop611
  • 488 Answers
SOURCE: Question the Ground tab on Switch which needs to
You can connect the ground wire to any of the black wires. They are all connected together inside the power supply..
Posted on Dec 15, 2009
Testimonial: "I have already figured it out and yes this is correct. "
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Jun 01, 2010 | Lorex SG6153 / Weather Resistant Mini...
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Jul 03, 2009 | Cobra HG-M75 Microphone
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
Jun 04, 2009 | Lorex SG6153 / Weather Resistant Mini...
Explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Apr 28, 2009 | Magnum DeltaForce CB Radio
MSI MOTHERBOARD - MS-6741 Ver:1 I have installed a 5 in 1 reader
yoyo
on the usb header on your motherboard 1 will have four pins and the lower row will have 5 or the other way around.......
the usb wires go as follows
red, white, green and black
top row left is red then white then green then the black this goes for the bottom row also is your card reader has to usb leads....
hope this helps
Rik
Jan 29, 2009 | MSI K8MM-ILSR Motherboard
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
Computers & Internet Logo
David Payne
David Payne
