THE FRIDGE IS NOT COOL ENOUGH BUT THE FREEZER IS ICING UP
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
SOURCE: Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
SOURCE: frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open
too long or after 4-6 months. I usually place two frozen milk jugs full
of water in the upper fridge and tape the upper fridge door closed at
night before bed so the kids don't open and let the upper food get
warm., Unplug the fridge and open the freezer and remove all drawers
(place excess frozen food in freezer in garage) , leaving the freezer
open with a towel in the bottom to catch the melting water from the
back panels inside and the next morning wipe the fridge bottom clean
and plug it back up and replace everything. I hate that I paid so much
for this fridge and have to defrost a couple times a year. However
found out too late to return back to the store. It seams like it should
have a cycle that heats the back plate every so often to warm and
evaporate the ice that collects, but I haven't heard or can't find
anything on that.
Kimsukie.
SOURCE: Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
