Question about De Dietrich 24 in. DVF120J Built-in Dishwasher
I have a de dietrich built in dishwasher vz9995U1 and it suddenly started leaking out of the bottom of the door. I can only find one filter to take out and clean. I have bought a lower spray arm hub and washer (someone suggested this in a similar online problem) but I don't know how to fit the part. Please can someone advise. Thank you
4 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Posted on Sep 21, 2009
MNfisherman
  • 11896 Answers
SOURCE: De Dietrich dishwasher model DVF300JU2
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Posted on Jul 12, 2010
ercupa190
  • 12223 Answers
SOURCE: where is the fuse on De Dietrich DVH610JU1 24 In. Built-In Dishwasher
see the pictorial and diagram
Posted on Sep 25, 2012
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Jul 27, 2011 | De Dietrich 24 in. DVI100 Built-in...
It does not rinse properly, leaving a film on
Pump worn out, using too much soap and depending on where you live there may be a more concentrated amount of minerals in the water. Florida residents are having that problem in spades due to our drought.
Oct 10, 2009 | De Dietrich 18 in. VZ9456 Built-In...
Washer starts program but sound much noisier than
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Wont switch on
try replacing on/off button or replacing the door switch.
thees parts sould be examind by technishian befor replacment.
Dec 28, 2007 | De Dietrich 24 in. DVF120J Built-in...
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
De Dietrich 24 in. DVF120J Built-in Dishwasher Logo
29 people viewed this question
Top De Dietrich Dishwashers Experts
ray gallant
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
