Question about Red Line Synthetic Oil 60202 Lead Substitute 12/12oz
What is a scallion
In food what is a scallion
    Sergeant:
  • 365 Answers
Scal·lion ?skaly?n/ noun North American noun: scallion; plural noun: scallions
  1. a long-necked onion with a small bulb, in particular a shallot or green onion.
Posted on May 13, 2015
Why Select a Vacuum Food Sealer?
You may have heard a lot about food sealers but you may not know them very well. Food sealer can provide you with an easy way to seal your food by removing air from the packages so that they will not get bad when you want to eat it. We all have experienced that we put food in the refrigerators and plan to eat it later, but later never comes. It's really a huge waste not only of food, but also of money. The food sealers work to prevent that waste by keeping your food fresh.
With a food sealer, you can buy fresh food as well as vegetables and take them home. Food sealers make it possible for you to buy food in bulk since you can seal and freeze it to avoid waste. It will remain fresh after a long time compared with the unsealed one. By removing air from the packages, you can take all of the air out of the packages. If you have air in them or put them in the refrigerators, you will allow germs to get into your food, which will make it become unsafe. If you do not eat it within a "safe time" and it's not well protected from the air in your fridges, you will have various odors from other food inside your fridges that can mess up the flavor. Your food may become discolored. This is because the freezers' pulling moisture out of the meat and vegetables due to your container allowing air into your food. Your frozen food will dry in the end. Although it's still safe to eat, it won't taste as good as it originally is. Food sealers are systems that seal food in air-tight vacuum packed systems like pouches and used for foods that need to be stored for long periods of time.
Anyway, food sealers can help reduce oxygen, limiting bacterial growth that would otherwise cause vegetables, meats and liquids to spoil. Sealing food guards against dehydration and freezer burn, and also saves on storage space because of the reduced size of the packaging. As an added perk, you can use the vacuum sealer to marinate meat or combine foods for ready-made meals. http://www.vacuumsealermanufacturer.com/
Aug 14, 2017 | Select Kitchen Appliances - Others
Tip
What is Food Dehydration all About
Food dehydration is a very long standing way of preserving food. In modern times, food dehydration machines have been developed, allowing people to dehydrate their food at home.
Dehydrators work by removing the moisture from food thus allowing them to last for much longer.
Because the water is removed at a very low temperature, the nutrients and enzymens of the food are not destroyed and that's why dehydrated food is seen as part of the healthy food movement.
How do you use a food dehydrator?
1. Wash and dry the foods you want to dehydrate
2. Arrange the slices on trays. Try and avoid overlapping.
3. Set the temperature using the guide. Generally the lower the temperature the greater the preservation of vitamins and nutrients.
4. Keep an eye on the trays, turning them in the dehydrator.
5. It can take anything from a couple of hours up to a day to dehydrate food, depending on the moisture levels.
6. When the food is ready store it in airtight plastic bags or containers.
Enjoy experimenting with your food dehydrator. It's fun for kids as well and is a great way of preserving fruit and vegetables when you've overbought or can see food would otherwise go to waste.
on Jan 02, 2014 | Kitchen Appliances - Others
Tip
General Tso's Tofu
Here is an amazing tofu recipe that i found online and unfortunately can\'t find the website where i copied it from. But it makes this (in my opinion) unflavored food taste like heaven.
Ingredients:
For the Tofu:
1 package of tofu
1 tbs arrowroot
3 tbs gluten-free, low-sodium tamari
1 tbs fresh ginger, grated or 1 tsp. ground
1-2 tbs canola or peanut oil
For the Sauce:
1 tbs sesame oil
1/4 cup gluten-free, low-sodium tamari
1 tbs arrowroot
3 tbs honey
2 tbs hot sauce (optional)
1 tbs canola oil or peanut oil
4-5 scallions, thinly sliced
4 cloves garlic, minced
Sesame seeds, for garnish
Instructions:
Cut the tofu into cubes. In a shallow bowl, combine the arrowroot, tamari and ginger. Whisk until smooth. Add the tofu and toss to coat.
Let the tofu marinate for at least half an hour, the longer the better.
When the tofu has marinated, heat 1 tbs of canola or peanut oil in a large skillet over medium-high heat.
Add the tofu to the skillet and cook until golden brown on all sides, about 4 minutes per side. Remove the tofu from the skillet and set aside.
Wipe out the skillet because you’re going to use it again.
In a large measuring cup or bowl, combine the sesame oil, tamari, arrowroot, ginger, honey and hot sauce, if using. Whisk until smooth. Set aside.
Heat the canola oil or peanut oil in the skillet over medium heat. Add the scallions and garlic and cook until fragrant, about 2-3 minutes.
Add the sauce to the skillet and let it cook until it thickens a bit. If it gets too thick, add some water.
Add the tofu to the skillet and toss to coat in the sauce and reheat the tofu.
Sprinkle some sesame seeds over the dish when ready to serve.
Bon Apetit!
on Oct 13, 2013 | Cooking
Is it true that this dog food is harmful to your dog?
Better to make your own for sure.
  • Review: Is Beneful® Bad for Dogs? - Feeding Fido and Fluffy www.feedingfidoandfluffy.com/review-is-beneful-bad-for-dogs Review: Is Beneful® Bad for Dogs? August 31, 2012. ... Here is the actual list of ingredients taken from the Beneful® Dog Food Healthy Weight web page:
  • PetMD: Why Dog Food Is Not For Cats, And Vice Versa www.petmd.com > Blogs > The Daily Vet Video embedded · But you'd be surprised to learn just how many of my cat owners feed their precious felines dog food ... dangerous to dogs' health? What ... cats dog food. ...
  • Is it true that Beneficial Dog Food is harmful to dogs ... www.fixya.com > Forum > Dog Food & Treats Beneful Dog Food this is link to snopes who say it is unproven. However if you do not want to risk it just feed your dog something else. The best top of the line most ...
  • Toxic and Dangerous Foods Your Dog Should Never Eat pets.webmd.com > Healthy Dogs > Slideshows A-Z Dangerous Foods for Dogs. Who can resist those big brown eyes and cute doggie grin? ... In fact, there's a lot of "people food" your dog should never eat.
  • Dog Food - Pet Care - 10 People Foods You Shouldn't Feed ... www.kidspot.com.au > MySpot > life Some human foods are very dangerous to a dog's health and should never be given to them, slipped under the table, ... While this is true, ...
  • Dec 16, 2015 | Dogs
    What's more expensive, cat food or dog food?
    Cat food is easily more expensive than dog food, due to dogs being biologically capable of processing vegetable proteins whereas cats cannot. This means cat food SHOULD only contain animal protein and is thus more expensive.
    Jul 25, 2012 | Cats
    What are the different types of cat food?
    Thedifferent types of cat food include: dry food, wet food, and home-cooked. Formore information on these types of cat food, check out this website: http://www.petuniversity.com/cats/health--nutrition/types-of-food/
    Jul 18, 2012 | Cats
    What are the different types of dog food?
    Different types of dog foods are:
    1. Wet foods that have high content of moisture in it.
    2. Dry foods that contains low amount of moisture.
    3. Semi-moist foods which have soft pellets with a chewy texture.
    4. Frozen foods that are available frozen or freeze-dried formats.
    Jul 18, 2012 | Dogs
    How to cook hamburgers - temperature, etc.
    Prepare Patties
    1. Put minced scallions and chopped mushrooms in bowl.
    2. Add red wine vinegar.
    3. Add ground beef to bowl.
    4. Mix everything together with your hands.
    5. Flatten the beef into four patties that are 1/2-inch thick and 5 inches in diameter.
    Cook Patties
    1. Set stove-top grill or burner to medium-high.
    2. Preheat nonstick frying pan. The pan is the correct temperature when a drop of water dances on its surface rather than sticking to it.
    3. Place patties in the pan and cook for 2 to 3 minutes.
    4. Flip patties and cook for another minute, and then add sliced cheese to the tops of patties if desired.
    5. Cover pan and allow burgers to cook for a final 2 minutes. Cook 3 to 4 minutes for well-done burgers.
    6. Remove hamburgers from pan and place in hamburger buns.
    7. Add condiments and toppings such as ketchup, mustard, sliced tomatoes, lettuce, red onions and pickles.
    Share some please! ü
    Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
    Jun 12, 2011 | Vacuums
    Red Line Synthetic Oil 60202 Lead Substitute 12/12oz Logo
    54 people viewed this question
    Top Redline Bikes Vehicle Parts & Accessories Experts
    nottmdon
    Level 1 Expert
    k24674
    Jonathan Buck
    Jonathan Buck
    Are you a Redline Bikes Vehicle Part and Accessory Expert? Answer questions, earn points and help others
